Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-12-2002, 03:18 PM
davip davip is offline
Default CD burn speed
I currently use Adaptec Jam to burn discs on an 8X burner. I remember that the Masterlist CD manual used to recommend always burning at the highest speed supported by your burner.
I have hundreds of disks at 8X, including many that have been sent off for replication, so maybe I shouldn't worry about this, but I'm wondering if Digi's recommendation still stands or if I should be burning critical audio disks at 1X or 2X rather than 8X.
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 01-13-2002, 07:47 PM
Shawn B Shawn B is offline
Default Re: CD burn speed
It's rather more complicated than that. It has to do with the depth of the pits burned into the cd. For each burner and each type of media it's different. Burners have different laser temps and the dye in the media have different melting temps. Your best bet is to find out which dye type your burner manufacturer recommends and stick with that. They usually set the laser temp to work best at the highest speed of the burner.(Although they do self calibrate for temp) If you are lucky enough to have a cd manufacturer in your town that will test you error rates then that is the best way. But most people don't have that luxury. Good luck!
where02190 where02190 is offline
We burn rough mixes at no more than 4x, and critical audio always at 1x.
Old 01-14-2002, 11:07 AM
MattiMattMatt MattiMattMatt is offline
The media itself is a factor in determining the ideal speeed. For discs manufactured by Mitsui (OEM'ed right and left), there are *less* errors at higher speeds.
Old 01-15-2002, 06:09 PM
roberts roberts is offline
I was told by a CD replication plant in Montreal Canada to burn audio masters as fast as possible as high speed masters have less errors.
Old 01-15-2002, 07:51 PM
John Stalberg John Stalberg is offline
I forgot to mention. With a specific brand of CDs and this specific burner there were no uncorrectable errors at a certain speed. This mean I will stick with the CDs and the speed with this particular burner. And sleeps good at night
If you change the type of the CDs you have to have them examined again of course.
This is a more satisfying method than to rely on the manufacturer of the burner. Never knows how exact their recommendations are. Can they say that you mustn´t burn with fast speeds for accurate results without shooting them self in the foot for example?
John
Master burn speed? fasttraxx Tips & Tricks 10 04-30-2007 09:47 AM
looking 4 losses vs burn speed info moosemaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-28-2001 08:48 PM
CDR Burn Speed nodell General Discussion 0 03-05-2001 11:34 AM
Audio CD Burn Speed shadowbox General Discussion 2 02-17-2001 07:10 PM
MLCD best CD burn speed? guitates Digidesign Hardware & Software 4 12-06-2000 06:46 AM
