In 7.3 - Old plugins are gone
I just upgraded to 7.3.1 CS2 from 7.2.
And noticed that some of the old plugins were gone. When I opened up the DEMO session, "Meant to Be" The Missing Plugin Dialog box opened up listing the following. 1-Band EQ 2 4-Band EQ 2 Compressor I found the the EQ 2 plugin in C:\ProgramFiles\Common Files\Digidesign\DAE\Plugins(Unused) folder. How did it end up in here? Am I suppose to manually copy it over to the plugins folder? And where's the original "Compressor" plugin? Thanks Tomio |
Re: In 7.3 - Old plugins are gone
yes you can drag them back into the (used)plug ins folder. this is normal in 7.3
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Re: In 7.3, etc - Old plugins settings are lost
So, Digi
This brings up the general question, "How do I take other previously working settings files and 'promote' them to newer plug-ins." Is there a way to read a previous settings file (like .tfx) and transform into settings we can use in our newer plug-ins? For example, when I watch my "Mix It Like A Record" video and see a number of plugins that I don't have [although I have similar ones; maybe not TLSpace, but I do have a convolution-reverb], how can I translate these to my plugins if I can't see the previous plugins settings? I would think I should be able to use a hex-dump utility, and knowing the .tfx file format, read the contents and at least hand-translate these settings. What is DIGI's solution? TIA, therm |
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library | Roll | Buy & Sell | 5 | 03-11-2013 06:20 AM |
Copy/Paste plugins settings between different plugins? | Zacsyd | Pro Tools 10 | 9 | 05-02-2012 07:26 AM |
Lateny Issue with PT8, 2009 mac Pro (OSX) and NI Plugins/Spectrasonic Plugins | djtorch | Pro Tools M-Powered (Mac) | 1 | 01-14-2010 12:11 PM |
Plugins missing in drop down list, but in plugins folder ?? | mixingmadness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 10:27 AM |
PLUGINS problem - paid for factory plugins, DON"T WORK!! | rhinostylee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-28-2007 10:59 AM |
