Old 01-29-2021, 09:53 AM
Macsearcher Macsearcher is offline
Default failing fader on S3
I'm wondering if anyone else has experienced this.
The 4th fader on my S3 calibrates on startup. It runs through the calibration routine successfully but when I open up a PT session, the fader does nothing. It happens with every session so I don't think that it's session related.
Not sure if I need to replace the fader. I'm in Canada so I don't think that it's all that easy to get one here.
Old 01-29-2021, 11:17 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: failing fader on S3
Not sure how techy you are, but the faders are fairly easy to remove and swap. I had the same issue with my secondhand S3 the day I bought it. I swapped it with fader 1 and all of them have been flawless ever since. It's possible the connection just got loose. It might be something else, though.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 01-31-2021, 06:24 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Yeah, like Ryan said, S3 faders are field replaceable. You can give Support a call and order some S3 faders.
1 - Power down/disconnect S3
2 - Flip over and place on soft surface
3 - Remove all screws holding bottom panel
4 - Disconnect failed fader from Controller Board
5 - Flip back over, remove fader cap and two screws - bad fader will drop out
6 - Install new fader and close back up
Pretty straight forward... just a lotta screws.
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 01-31-2021, 08:47 AM
Excessive screw count on an Avid product? How unusual... ;-)
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-31-2021, 11:23 AM
Thanks for the advice everyone.
I will order a new fader from support. I'd like to rule out that it could be some other issue though.
The fact that the fader passes calibration on startup and then just sits dead during a session is a bit strange to me.
I a may try the earlier suggestion of switching it out with another fader module.
Old 01-31-2021, 11:27 PM
Ryan Young's Avatar
https://www.ebay.com/itm/333875186683
Not sure if it’s any cheaper than through Avid but this may help. Easy to replace.
-Ryan Young
Additional Systems
Avid Profile Fader Bay Circuit Boards failing [email protected] VENUE Live Sound Systems 1 12-13-2015 11:07 PM
Failing to get pre-roll bruce_pianoman Pro Tools 10 8 03-26-2013 04:56 PM
5.1.1 installation failing festudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-02-2005 04:52 PM
SSC FAILING TO OPEN! wmcintyre Pro Tools TDM Systems (Mac) 6 08-28-2002 06:45 AM
DSP failing Whisky Digidesign Hardware & Software 0 07-07-2000 07:44 AM
