noob midi problem
hi all
im having problems connecting my midi keyboard to protools 8. Im running vista ultimate. I have plugged the midi out from my keyboard into the midi in of my rack 003+. I can play the keyboard and get a green flashing light on the front of the 003. when i go in to PT under 'midi studio setup' there is no option at all. midi thru is enabled. im totally new to midi and need some help. do i need a cable from the 003 midi out into my keyboard midi in? i really just want to fool around with some instrument plugins. any help would be really appreciated. thanks. |
Re: noob midi problem
Did u open a VI? What type of track did u open it on? what type of controller? what midi channel? which VI?
ok, so lets say i open a new session - new midi track
in mix window, input is set to "all", output is "McMIDIM[E]1". my other options for output are "redefined - Microsoft GS Wavetable snyth" or "Microsoft midi mapper". record enabled with the "McM" output comes up no signal. im using a novation remote SL keyboard. thanks |
OK where I see ur problem; U REALLY need to give more info on what ur actually doing & trying to do...
sorry
im totally new to midi setup. i basically just want to create a instrument track, put on a plugin, say a "mini grand", play the novation, hear it through my monitors connected to the rack 003 and possibly record it. i started by following the protools reference guide, got as far as "enabling input devices". Its not showing in my PT under setup - midi - input devices. done a bit of googling. more confused than anything. thanks |
If u have midi hooked up, that honestly should be it; Midi Studio is irrelevant; Open an Instrument track, insert mini grand & that is it... As long as u have Midi thru checked...
AGAIN, u still haven't given anyone any info as to what i asked above so I myself will let u figure this 1 out urself or maybe som1 else may chime in...
Noob - 3 USB problem | jremsley | macOS | 6 | 04-06-2012 04:25 PM |
Noob MIDI Question | evyngyle | MIDI | 2 | 12-11-2009 02:39 AM |
noob question....midi keyboard? | chevy454 | General Discussion | 14 | 09-29-2009 02:02 AM |
noob to PT, help with midi | Max Dible | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2006 11:30 PM |
noob needs help with midi sequencing | ilovecrack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-16-2005 09:30 AM |
