automate midi routing?
Hi there,
basically I'd like my keyboard to control one instrument at the beginning of the song and then automatically switching to another instrument halfway trough... If each instrument input was assigned to a different midi channel then automating midi routing of the keyboard would allow me to do that but I don't think it's possible... Any other ideas or way around it? Thanks! |
Re: automate midi routing?
If your MIDI Controller supports Zones you can assign MIDI Channel messages and key range for respective Virtual Instruments.
filosofem |
I notice you're pretty knowledgeable with MIDI in general as well as the Axiom Pro.. I'm trying to figure out why automation isn't recording my parameter manipulations with my Axiom Pro or Kore 2 using Komplete 6... Example.. I record a synth patch going between two chords over and over. I arm automation on that instrument track and then hit play, tweaking the parameters (envelopes, filters, etc) as the chords play out. Under normal circumstances with audio track automation, everything you hear should be recorded to a T. But with MIDI, for me at least, I hear everything as I'm tweaking, but when I play back... it plays the very last state of the tweaks I made. Nothing is recorded. Anyway, sorry to hi-jack this post... but I could use some help!!
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts." -Albert Einstein Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub |
Automate External Hardware synth via MIDI CC | tj2toxic | Pro Tools 10 | 4 | 03-18-2013 03:46 PM |
Automate External Hardware synth via MIDI CC | tj2toxic | Windows | 1 | 03-18-2013 07:19 AM |
PT9 + Mbox3 Pro Midi Port question + RTAS midi routing | mrwolfe | macOS | 0 | 05-29-2011 11:24 PM |
Using MIDI to automate my 01V | PhilHall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-15-2006 04:18 PM |
Can I automate midi instrument midi volume slider? | ChaplainPC | MIDI | 6 | 07-08-2006 06:33 PM |
