Old 11-17-2021, 11:14 AM
herrturtur herrturtur is offline
Default Plugin Control with HUI (X-Touch)
is there any way to control plugins that support control over HUI?
I had an X-Touch ONE and even upgraded to the 8 fader X-Touch (knowing of all the limitations of HUI Protocol before). I like working with it.
I discovered that (e.g.) softube plugins display the same blue frames around some plugin controls that the PT channels display when selected with the X-Touch. I could not find out how to control these with the controller. I searched a lot on the web, but no luck.
If that helps anyone, the only reason I kept the X-Touch One in the first place (same is possible with the X-Touch), is that you can "jump" with the eight-block-of-channels to any channel in the mixer by ctrl+shift+clicking on a channel. I stumbled across this by accident in a forum after long searching. I think that stepping through sessions by clicking the fader bank button is such a workflow killer, that without the feature of "jumping to channels" the X-Touch would be unusable for me.
Old 11-19-2021, 08:10 AM
Default Re: Plugin Control with HUI (X-Touch)
Check out Nyrinck V-Control with the new Presonus Faderport. It looks pretty amazing to me. Sadly the original Faderport(which I have) doesn't work the same
touch screen control of PT? blankpro Pro Tools 12 18 05-04-2017 07:47 PM
Instrument Plugin opens every time I touch fader [email protected] Artist Series 1 12-05-2016 09:32 AM
Artist Control V1 Touch Screen Xill Artist Series 3 08-19-2011 01:52 PM
Touch to select on MC mix, does control touch screen follow? Led Artist Series 0 03-24-2011 05:36 AM
Best sub-$500 Touch Control Surface? Toonvox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-13-2005 06:06 PM
