Old 11-11-2021, 12:29 AM
b mcgibney b mcgibney is offline
Default How to write midi notes all the way up to G10 for BFD
I'm using BFD 3 to put in some grooves. The problem is that the default groove assignments go up to G 10 but I cannot get that high up in the protools midi editor. Am I missing something obvious here?
B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Old 11-11-2021, 02:12 AM
Marsdy Marsdy is offline
Default Re: How to write midi notes all the way up to G10 for BFD
B
I don't think G10 exists in Pro Tools or in most other places! There are 128 MIDI notes and the default in PT is C3 = MIDI note 60. G10 would be something like note 151 which doesn't exist!
Dave Marsden
UK
Old 11-11-2021, 09:27 AM
So the BFD key map is mapping notes outside the standard MIDI protocol? Interestingly enough if I transpose my Motif all the way up I can access the Logie 10 to play the pattern, or groove as it’s referred to in BFD parlance, Unlike strike, BFD drums has a whole bunch of extra articulations assigned to all the notes below C8.
=Marsdy;2619002]I don't think G10 exists in Pro Tools or in most other places! There are 128 MIDI notes and the default in PT is C3 = MIDI note 60. G10 would be something like note 151 which doesn't exist![/QUOTE]
Old 11-11-2021, 09:29 AM
[QUOTE
G 10 not Logie 10
=b mcgibney;2619039]So the BFD key map is mapping notes outside the standard MIDI protocol? Interestingly enough if I transpose my Motif all the way up I can access the Logie 10 to play the pattern, or groove as it’s referred to in BFD parlance, Unlike strike, BFD drums has a whole bunch of extra articulations assigned to all the notes below C8.
=Marsdy;2619002]I don't think G10 exists in Pro Tools or in most other places! There are 128 MIDI notes and the default in PT is C3 = MIDI note 60. G10 would be something like note 151 which doesn't exist![/QUOTE][/QUOTE]
Old 11-11-2021, 09:42 AM
[/QUOTE]
The MIDI spec allows for 128 MIDI notes so I guess it’s where you start counting from! PT will see middle C as C3 or C4 and count that as MIDI note #60 of 128.
Where are you seeing G10 in BFD? If it’s to trigger a groove I’m seeing the groove triggers start at C6 going up to G8 or note #127 which would show up in PT.
Dave Marsden
UK
Old 11-11-2021, 06:48 PM
I think I am going to have to remap the grooves in BFD. I've tried to attach an image of what I am seeing in the BFD keycap window. Currently the Grooves START at C8 and Go to G10
Where are you seeing G10 in BFD? If it’s to trigger a groove I’m seeing the groove triggers start at C6 going up to G8 or note #127 which would show up in PT.[/QUOTE]
File Type: pdf Screen%20Shot%202021-11-11%20at%206.17.45%20PM.pdf (112.9 KB, 0 views)
Old 11-12-2021, 01:12 AM
[/QUOTE]
I'm not sure how you've got the grooves starting at C8. As it happens I did a clean installation of BFD3 this week and the default factory mapping has the grooves starting at C6.
By default you should be able to trigger everything, drums and grooves from Pro Tools so yes, it would make sense to remap the grooves.
Dave Marsden
UK
Midi notes deleting when editing and writing in notes SeventhSounding MIDI 5 01-14-2018 02:34 AM
can't write MIDI notes any more clausiii Pro Tools 12 4 05-14-2017 09:50 AM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
Newbie..Recording MIDI.. how to write notes to PT..?? luism 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-07-2008 10:00 PM
I can WRITE midi notes, but midi controller won't. ::mitch:: MIDI 4 10-17-2002 03:29 PM
