Old 12-15-2011, 08:42 AM
dts350z dts350z is offline
Default importing midi
When I do file--> import --> midi, and select a midi file, when I click open nothing happens. The file dialog is still open?
I can drag the same file into a session, but then I don't get to use the tempo in the midi file.
Am I doing something wrong or is this a PT 10 bug?
Old 12-17-2011, 10:04 AM
Default Re: importing midi
I see that I had posted this same questing under PT 9, with no working fix either.
Here's an update, If I run the midi files through a midi file format converter to type 0, then they import as expected.
However, I'm not convinced that's the whole story, because I moved one of the working type 0 files from one PT machine to another, via gmail attachment, and it stopped working so it seems that maybe there is something that is not "bit perfect" in up/downloading midifiles that pro tools doesn't like.
I'll try converting the same problem files to type 1 format and see if that also works, and report back, under the theory that that the file conversion is "fixing" a format problem vs. Pro Tools not supporting one of the two midi file types.
Old 12-17-2011, 01:10 PM
Where did the SMF originate?
Aaron Mulqueen - 001 HD Native
Old 12-17-2011, 03:35 PM
An example here:
http://www.classicalmidiconnection.c...roModerato.mid
I also tried running it through Plogue Bidule, so as to re-record the file, but the results still didn't load into Pro Tools.
Old 12-18-2011, 02:19 AM
Richard901 Richard901 is offline
PT 9.0.3 for MAC imports the MIDI file correctly (8 tracks).
One idea:
Right-clicking on "Allegro Moderato" just saves an shtml file which is not the MIDI file.
BUT
Left-click on "Allegro Moderato".
The MIDI files plays.
Right-click on here and save the file.
The file is a MIDI file which Pro Tools imports correctly.
*****EDIT******
Just read your first post again. Obviously you have downloaded the MIDI file correctly, because you can drag it into Pro tools.
I'll have to learn to read!
Pro Tools 2023.9
Ventura 13.6
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
IMPORTING MIDI..... KRAFT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-15-2007 06:02 PM
6.4 importing MIDI jc7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-27-2007 04:06 PM
importing midi jackruston Pro Tools TDM Systems (Mac) 5 08-01-2001 01:39 AM
Importing a MIDI track into PT5 (for a MIDI knucklehead) Farmer Dave Pro Tools TDM Systems (Mac) 0 04-04-2000 05:41 PM
