New saffire pro 40
I just bought a saffire pro 40 off sweetwater. I was just curious to hear any feedback related to it and pro tools 10. I'm uprgading from the digi 002 rack.
Re: New saffire pro 40
I use the Pro 40 with PT10 and so far its rock solid. Just spent the whole day tracking drums in an old church on a MBP and no hiccups at all.
I would suggest learning MixControl throughly as its a huge help when setting up zero latency headphone mixes etc. And if you've got any troubles, Focusrite customer support is outstanding Enjoy!
2011 MacBook Pro 13" 2.7GHz i7 8GB RAM
Mac OS X 10.9.3 Mavericks Pro Tools 11.1.3 Focusrite Saffire Pro 40 w/ Saffire MixControl v3.4 Focusrite Forte with Forte Control v1.1 |
I was with PD today and was actually impressed with this unit.. A good piece of kit in my opinion...
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
I've used a Saffire Pro 40 together with an Octopre Mk2 as my main interface for the past year, initially under PT9, and now PT10. Works wonderfully, right down to a 64 sample buffer on my Avid-qualified Windows 7 64-bit system. I'm very impressed with it.
Two small bits of advice, though - firstly make sure you use the latest 2.4 drivers. There *are* problems with anything before this. Secondly, as the previous posters say, make sure you learn the ins-and-outs of MixControl. It's very powerful, but some of its little idiosyncrasies take some getting used to. Clive |
Cool post I am thinking of getting a saffire too ,
focusrite liquid saffire 56 ,digi rack 02/ presonus digimax 8, allen heath gl2432, mobo asus m4a88td-v evo/usb3, AMD 1075 sixcore corsair XMS3 ddr3 4g (x4) western digital 1tb hard drive 7200rpm(x 2), 680watt power supply no name, windows7 home premium 64 bit |
I was thinking about upgrading to this from the 002 as well. Does mix control allow you to keep the digital ins or two of the analog ins routed to the monitors? I am wondering if I will miss the "alt src to monitors" button on the 002.
I have the pro 40 and have expanded it to 18 pre amps in and 18 ch. out by taking advantage of the ADAT and SPDIF ins and outs.
Bheringer ADA8000 to ADAT ART DPS-II to SPDIF The Art DPS-II provides sync to the Pro-40 and the Pro-40 provides sync to the Bheringer. I'm working in 5.1 surround and use the pro 40 outputs to drive my 5.1 monitor system as well as a stereo headphone mix, using the included saffire mix application (There is also an RTAS version now I haven't tried yet). |
I just purchased one and I am going to hook it up tonight. I have a question though. I bought one as a demo model from sweetwater for $369 but it didnt come with an installation disk. I also cant find an saffire pro 40 driver disk on the focusrite website. If I just install mix control 2.4 will I be okay?
Another question is what made you decide to buy the Saffire and how does it compare to some of the higher priced interfaces? thanks |
Best bang (8 PREs) for the buck. Lot's of flexibility and (with some research) expandability.
If I recall correctly you just use the windows native (legacy) firewire driver. The Avid setup guide for windows describes setting up that driver. I guess you didn't mention which platform you are on. I'm mainly on windows but have also used in on a mac. Just plugged it in and it worked. |
So I dont need to install any drivers other than the mix control? I have a Imac I plan to put the pro 40 on. But if it works and sounds great I will either get another one or Liquid Saffire 56, maybe a MR816csx or the new UR824 for my PC. Thanks.
PT HD on saffire pro 40 or 56? | rustyjay | Third Party Interfaces | 6 | 05-04-2017 01:47 PM |
Pt 10+ liquid saffire 56+ saffire pro 40 masterclock? | Nightworker | Pro Tools 10 | 16 | 12-08-2012 10:29 PM |
003 with saffire | peterreal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-27-2012 04:10 PM |
saffire pro 40 vs liquid saffire 56 | AxeDye | Pro Tools 9 | 9 | 12-09-2010 05:19 PM |
PT 9 and Saffire 56 | Empireofthesun | Pro Tools 9 | 0 | 11-05-2010 03:32 PM |
