#21
Re: Miroslav Philharmonik No Brainer deal - $15!
I requested this as an option on their Sampletank3 suggestions forum.
#22
That registration, download, authorization, etc. process is way more complicated than it should be.
I need help w/ 2 things: 1. When downloading the sounds from the User Area (after istalling and authorizing the instrument/plugin), part one of the download went ok and installed fine. In part 2, while extracting the files, about 4/5 of the way through the extraction I was told (little pop-up window) that certain of the files needed passwords and prompted me for the password. I searched the multiple e-mails and download instructions but could not find any info regarding a password for certain of the sound files (they were certain of the Clarinet sound files). I tried my normal IK Multimedia password but it didn't work. I had to press "skip file" for these files to continue. Then when it finally got through, I got an error saying there was an error installing the files. DID THIS HAPPEN TO ANYONE ELSE? 2. Just to see what this product sounds like (at least one of the sound downloads went correctly) - I launched Pro Tools and created a blank session. I followed the instructions from the manual - created a stereo audio track, added MPCE as an insert - created a midi track, selected MPCE channel 1 as the midi track's output, record enabled the midi track, selected a sound from the MPCE instrument menu, clicked it, it then appeared in channel 1, played my keyboard and - nothing. no sound. I'll admit that perhaps I am doing something wrong here, but can't figure it out. the input meter/indicater moves when I play the keys, but no sound. Any ideas? **EDIT** Problem 2 solved! I would have simply deleted No. 2 from my post, but this is kind of funny, so I figured I'd tell what happened. To test I had selected a couple of different istruments violins, violas, and reached over to the keyboard and hit a few nearby notes just to hear the sound. The problem? I have an 88 key heyboard and was playing notes that were out of the range (too low) for the selected instrument!! Still need help for the first one, though. Those sounds aren't available for use. thanks! FWIW, first impressions - sounds OK. Sounds fake-ish - not going to fool anybody with these sounds, but definitely worth $15. |
#23
I snagged this one also. It will most definitely find use.
#24
Where's the user manual for this CE version? I can't find it on their site, or anywhere with my install. Help - I must be missing something !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#25
im not sure if they have one for just the CE edition.
Here is all i could find for CE http://www.ikstore.com/News/Uploads/.../0725_1928.pdf and some videos for the full version http://www.ikmultimedia.com/philharmonik/videodemo/
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
#26
Is there a manual for the full version then? Edit : I found it. It's in the Programs x86 ---> IK Multimedia folder (duh...).
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume Last edited by EGS; 04-03-2011 at 02:21 PM. Reason: found it !!! |
#27
Okay, today I'm trying this Miroslav VI for the first time. Some of the samples momentarily crackle and skip, at which point the PTools CPU/RTAS meter spikes. I'm running buffer 64, 8 processors at 85%. Same spike occurs at 128/7/85. Xpand 2 works at these settings, but if I add a Miroslav instrument to the session, Xpand2 also spikes the same way. I do use a separate samples drive, but that shouldn't even matter since apparently Miroslav loads samples into RAM. Thanks for the help !!!
#28
#29
For me IK plugs work much better when PT is launched with R.A.A.
#30
Yes - running as admin. Anybody else getting Miroslav spikes? All my plugs are updated versions for 9.0.2. Help !!!
Way to get key switching with Miroslav Philharmonik? | gsrokmix | Virtual Instruments | 4 | 06-12-2012 02:22 PM |
Miroslav Philharmonik problems/PT 10 | bonzerboy | General Discussion | 5 | 03-12-2012 06:55 PM |
What should I do with this Miroslav Philharmonik-problem? | stump | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-03-2011 10:52 PM |
Miroslav Philharmonik? | garnoil | Pro Tools TDM Systems (Mac) | 22 | 03-15-2009 08:11 PM |
Miroslav Philharmonik | wernerbachmüller | Virtual Instruments | 1 | 09-18-2006 07:35 PM |
