Old 01-07-2010, 04:40 PM
StinkyPete StinkyPete is offline
Default Alesis Multimix 12 USB
I recently came into possession of an Alesis Multimix 12 USB interface that a friend of mine said he used with his LE system. From the research I've done online it seems it's possible to use with ProTools but I'm unable to make it happen. Is it possible? If so does anyone know what I need to do? Thank you in advance
Old 01-07-2010, 04:43 PM
Craig F Craig F is offline
Default Re: Alesis Multimix 12 USB
your friend is ether mistaken or a flat out lier.
Pro Tools LE only works with mBox or 002|3 interfaces
Pro Tools M-Powerd works with M-Audio interfaces or 1 Mackie interface
Thank you,
Craig
Old 01-07-2010, 06:11 PM
nedorama nedorama is offline
Or...
they used it in analog mode as a regular mixer, not using the USB port.
they used it and their LE interface and aggregated both in Core Audio to do non-Pro Tools audio.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Alesis MultiMix 4 USB interface not available as an Input Designer66 Getting Started 9 05-29-2013 02:27 PM
PT 10 with Alesis Multimix 8 USB on Windows? jimlad Windows 0 02-19-2012 04:33 PM
Alesis Multimix 4 USB Toolbar Pro Tools 10 0 12-01-2011 06:49 AM
Alesis Multimix 16 dolgand Pro Tools 9 0 11-17-2010 03:28 AM
Using Alesis Multimix FW 16 with PT M-Box foxlemieux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-01-2005 01:36 PM
