Re: new 003r, no pres?!
i'm testing continuity.
and i'm recording to an audio track... iknow better than to try to use an instrument track lol... |
just tried to set up again, the only pre that gives me mic signal is #4... i have no clue whats wrong..
- phantom power is engaged
- xlr into input 1 - no mic button is needed - input 1 (gain) is open (turned up) - in pt, audio track has its input as analog 1 - track is record enabled. - the i/o setup is correct. I'd don't get why "no mic button is needed"... If you don't select mic with the button you are recording the line inputs, which I'm certain you know. Is the above a mis-statement? My only suggestion Re: setup is to make sure that the track is set to "Input only monitoring". That'll mess you up...
Learn to listen. Listen to learn. |
Mikeren, thanks for the response,
the mic button is engaged only when you need to switch it to DI (its a mic/di button) (on a 003r) ill check input only monitorint (opt+i) but i cant see it being the problem as i'm not getting level? |
Can you input line or DI signals via 1-3?
Are you testing 1 thru 4 with the same mic/cable? This may sound crazy considering the problems with core audio but try to use the 003 with Garage Band (if the 003 is connected but not being used by ProTools, you should be able to choose it as the audio input source from within GB) This would isolate the problem to either ProTools or the 003
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
#16
As I recall there was a issue with the 003 (or possibly 003+) that involved the bundle of wires connecting the preamp being bundled too tight and pulling the connector off. The solution was to to cut the wire tie to release the tension and re seat the connector. You might want to check with Digi during buisness hours. This is not the same thing as the 002's power harness issue
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#17
sigh... i had to do the power harness on myold 002... and now this?
i'm so tired of this. |
#18
Have you check your cable(s) for low resistance shorts
I had a 200 ohm short in a patchbay once, it was enough so beep testing passed but actual signal shorted out
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
#19
@Craig, the cables are fine, and so is the mic. (just bought brand new cables)
also, can anyone link some info on the wiring problem? |
#20
The more I think about it I beleive that issue may have been unique the 003 console. Sorry I don't have a link.
What's better... BLA 002R Mod Pres or DigiMax FS Pres via Lightpipe? | DeyBwah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-04-2010 07:39 PM |
Digi max fs pres vs. 003 pres. | KevinAllen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 01-26-2010 05:18 PM |
003r Pres vs UA LA-610? | dts.music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-24-2007 10:50 PM |
budget tube pres vs. 002R's pres | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-12-2003 05:04 AM |
001 pres or Mackie pres??? | QuikDraw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-04-2002 12:39 AM |
