Old 07-03-2002, 03:54 AM
simonchase simonchase is offline
Default disk error 37 on "Save session copy in"
When trying to save session copy in (with audio files) i get disk error 37. Any clues?
Thanks
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 07-03-2002, 07:23 AM
cakehead cakehead is offline
Default Re: disk error 37 on "Save session copy in"
just a thought...it might be a corrupt fade or ausdio file.....try consolidating all regions and see if you can do a session copy.then
Old 07-03-2002, 09:10 AM
putney2 putney2 is offline
From the apple tech library
-37 | bdNamErr | Bad file name; there may be bad names in the final system!
Try using norton utilities or disk warrior.
error codes 0-261
-russell,OPA
Old 07-03-2002, 02:17 PM
gugu gugu is offline
Hi
Error 37 is about filenames. Try to find if your session is not using 2 files with the same name (it happens to me with a session using files (ex: Gtr 1) located in 2 different Audio Files folders). If you duplicate these files and delete unused evererything works fine again...
hth
gugu
"Save copy in..." function copies files that have been cleared from session. ragbor Pro Tools TDM Systems (Mac) 7 02-08-2010 12:25 PM
disk error 37 on "Save session copy in" simonchase Pro Tools TDM Systems (Mac) 0 07-03-2002 03:37 AM
Disc error -37 during "Save session copy in..." Arbuz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-07-2002 10:20 AM
"save session copy in" audio file name shortening simonchase Pro Tools TDM Systems (Mac) 2 05-10-2002 04:39 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
