Digital noise on my digi002 when recording
Hi
I have a Macbook pro, and both logic pro and Pro Tools 7.1.1. I want to use my Digi002 as an audio interface for Logic. It works as a player, but if i try to record i get 0dbfs white noise. I've tried to record in Pro tools with the same setup, it works perfectly. The problem is in Logic pro and other applications. Mac Book Pro Mac OS X (10.4.8) |
Re: Digital noise on my digi002 when recording
Just go there!!
http://www.digidesign.com/index.cfm?...4&itemid=23146 "Fixed: When Using CoreAudio Input To Record With Third Party Applications, Digital Noise Would Result. (Item # 78481) Note that this problem only occurs with Intel-based Macs." You have to update this CS .....
MACPRO BI 2,66 +5Go RAM+ OS 10.6.8 FRENCH SYSTEM + DIGI002 RACK Protools 9.06 www.myspace.com/alx002 |
Thanks
It worked. That was the only problem..... |
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? | PeterGreen | Pro Tools 10 | 24 | 01-23-2013 06:38 AM |
Digital noise and glitches when recording to gdrive | antward | Pro Tools M-Powered (Mac) | 2 | 05-13-2011 07:43 AM |
Digital Noise on Digi002 Recordings : Please Help! | Martin Massinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-05-2008 10:51 AM |
Digital I/O on Digi002 | joshdavis20 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2002 11:17 PM |
Recording 16bit digital to 24bit digital | Tips & Tricks | 2 | 03-13-2000 11:37 PM |
