Old 11-12-2021, 10:33 AM
herrturtur herrturtur is offline
Default Pro Tools displaying incorrect wave form / iZotope RX8
I opened a 44.1 kHz / 24 bit session and imported a 44.1 kHz / 24 bit file, a song that I re-sampled from 48k with iZotope RX8 for CD master. (The original masters are 48k). The waveform of the 44.1 k file (created by RX8) is totally incorrect at some points. Let me explain:
for better understanding, let's call
the RX8 converted file from originally 48k to -> 44.1k "file A"
and
the original master 48k file "file B"
I loaded file A (44.1) into the 44 PT session and also file B, so that PT had to convert file B it into 44. I wanted to see what the conversion in PT does to the file. I was shocked, because file A displayed absolutely strange waveforms. Since I used the "post limiter" option in RX8 for creating file A, I thought it had processed the file a lot when converting to 44. Listening A/B in Pt I could not hear a difference between file A und B. Null testing against each other gave perfect silence. I never encountered PT showing incorrect wave forms. Any idea where that comes from?
See attached, the dynamics look different, but sound the same and null:
I tested with another song (same procedure as above, original was mastered in 48k). The song ends with silence / reverb tail. The RX8 converted file shows absolutely incorrect waveforms, both tracks in PT sound the same (as the one below, file B, which is showing the correct waveform): see attached
any ideas?
Old 11-12-2021, 11:04 AM
BScout BScout is offline
Default Re: Pro Tools displaying incorrect wave form / iZotope RX8
Recalculate waveforms and see if that corrects it.
Old 11-12-2021, 12:03 PM
that did it. Thanks! Feel a bit stupid though
How can I see a EQ wave form while I EQ phatbeatstudio Pro Tools TDM Systems (Mac) 29 09-10-2011 07:34 AM
Pro tools wave form problem? bn_sander General Discussion 4 01-05-2010 10:35 AM
Wave form mandolinman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-05-2008 09:55 AM
Wave Form Drawback audio1420 Pro Tools TDM Systems (Win) 0 11-29-2006 11:40 AM
wave form during recording HAIRCUTS91 General Discussion 4 10-08-2006 10:09 AM
