Old 12-06-2019, 04:04 PM
TimTee TimTee is offline
Default Re: Follow up protools control 19.9.1.7
this from above:
iMac with PT 2019.6, eucontrol 19.12.071 and latest app on iPad air1
didn't know how to get iPad app ver # but its the very latest on the App Store as of a few hours ago.
Just went through the uninstall via the installer (didn't know you had to do that...) (selected uninstall and trash the prefs) and same thing. Tried quitting all apps multiple times, restarting etc., no go whatsoever. I set this up before and think I know the process but either Im missing something or something's up.
Also checked rechecked that both iPad and iMac with PT are on same 5G network and its working as well. Thanks
I have not uninstalled the iPad app and reinstalled. tho.
Old 12-06-2019, 04:05 PM
EddieJones's Avatar
Can you confirm the version of the App in the Settings About tab in the App. I ask this as only a couple of hours ago i has someone with the same issue and the App wasn't the correct version
Old 12-06-2019, 04:09 PM
on iPad app its v19.9.1.17
Old 12-06-2019, 04:10 PM
EddieJones's Avatar
Thats the issue..its still the old version. It should be 19.12. What iOS version is the iPad on ?
Old 12-06-2019, 04:14 PM
11.2.5
ipad air1
There is an update it shows to 12.4.3
Old 12-06-2019, 04:15 PM
EddieJones's Avatar
I pretty certain you need to be on v12 to get the new version of our App...I'd update then try again
Old 12-06-2019, 04:17 PM
I'll do that now thanks.
I also see the air1 is done for for updates in future, it won't go to iOS13 anymore. Hopefully future updates to the app will will within iOS12 for the next while.
This is precisely why I stay several versions behind before updating... why I hit update...
Old 12-06-2019, 04:21 PM
EddieJones's Avatar
Yep this is totally up to Apple. Our App will support v12 as long as Apple allows it. I don't think that will change anytime soon though.
Old 12-06-2019, 04:55 PM
dear god it worked. Thanks for solving this.
Any way to get the Control app to no follow application changes on my computer? jkess Avid S1, S3, Dock and Control App 1 08-28-2017 06:08 PM
How do I get the expression pedal to follow in patch canges (ground control pro) magie78 Eleven Rack 2 11-27-2011 10:38 AM
Mc mix-protools 9- bank select follow? priorytools Artist Series 1 11-08-2011 10:57 AM
MC Control follow selected track? thebeatless Artist Series 0 03-07-2011 10:14 PM
follow Protools playback AfricanCaneKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-10-2004 08:39 PM
