Trouble reinstalling Protools Le 8
Hi There
I am trying to reinstall Protools Le 8 and having some trouble. Perhaps one of you have seen this before. On installation everything proceeds normally until I get to the stage where "3rd party content" is loaded. At this stage I get an error message saying Install Failed - The installer could not install some files in "/." Contact the software manufacture for assistance. Reason for reinstalling is that my Mbox mini stopped working. on further investigation i realised that Protools had stopped functioning. Hence I decided to uninstall protools and and reinstall. I'm running Mac OS X 10.5.5. Thanks in advance for you help Cheers dalla |
Re: Trouble reinstalling Protools Le 8
I haven't seen this problem personally, but I would try:
completing the uninstal repair permissions install PT with out any plugins or add ons if that works successfully, then try to instal any plugins and addons you want installed Hope that helps K
https://wanderingear.net |
What Mac are you using? How are you uninstalling Pro Tools?
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Hi
Thanks for the reponses so far. Since my post I notice that despite the install not completing and ending with the summary. it still results in the files being loaded and the executable being available. So then when i launch PT it stops before completing the launch claiming it can't find the mbox. I tried plugging and unplugging and different USB sockets and the "power on LED" on the mbox refuses to light up. The mbox does work however when plugged into a PC? Haven't yet tried the repair permissions mentioned above - will check that out tonight? If there are any other suggestions in the mean time, I'd be grateful. Cheers Dalla |
Cheers and thanks for the help so far. Dalla |
My Mbox now works....yeah So now the only thing is that when I try to launch i get the follow error message "Could not complete the requested because you do not have the appropriate access privileges (-5000) whilst opening ".IP_PlaceMent". Any suggestions? |
This may seem obvious but I realised the problem listed above was due to me running PT for the first time after installation under a different user profile other than Administrator. Running it first under admin I was able to enter the authorisation codes. All is now fine.
Having Troube Reinstalling ProTools LE 8 | devintrier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-03-2012 03:45 PM |
Trouble reinstalling MBOX2 Pro onto Vista | badgerspanner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-17-2011 11:36 AM |
Having trouble reinstalling pro tools 9 (installer encountered error) | iriebillie | macOS | 2 | 09-21-2011 01:54 PM |
Reinstalling Protools / Digi001 | morellamusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-28-2006 03:19 PM |
Trouble reinstalling 002 after a system recovery | oregafro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-03-2006 02:47 PM |
