Old 12-17-2010, 05:45 AM
Stig Eliassen's Avatar
Default Playback engine & Input monitoring
Why is it that the number of voices/DSPs doesn't get saved with the session? I recently had to up it from 96/3 to 128/4, and I get asked every time I open the session if I want to use 128/4?
BTW - I swear this has something to do with the fact that I've just started having the audio print track monitoring input at all times.
BTW #2 - since I started using input monitoring on the print track, I can no longer leave the session open over night. When I get back the next day, PT is mindnumbingly slow and unresponsive, and I have to quit and reboot. Today, PT wouldn't quit either, so I had to force quit.
Thoughts on the subjects?
Old 12-17-2010, 05:55 AM
Bassturbator Bassturbator is offline
Default Re: Playback engine & Input monitoring
That's because it IS saved with the session :)
You probably saved that session while your setting was 128/4, but now you're using 96/3 on some other stuff, right?
Or am I completely missing it? haha
Old 12-17-2010, 06:14 AM
I probably should've said that it doesn't get saved with this session. I've been working on the same session for days. I've done many Save As..., but that shouldn't matter at all.
Oh, and I misread the error message. It actually is saved with the session, but PT acts as if I've been working with 96/3 prior to opening this session, which I most definitely haven't.
Old 12-17-2010, 06:29 AM
Aaaaah okay, that's indeed a different story...
Hmm... nothing really comes to mind apart from doing "the obvious" I'm afraid (thrashing prefs etc...).
Maybe try to make a new session and import from the old one?
Old 12-17-2010, 06:49 AM
formfunction formfunction is offline
Stig, I am very curious. Why do you leave the session open overnight? thanks, ff
Old 12-17-2010, 08:02 AM
I'm confused. It doesn't happen anymore. Doesn't matter if I save with input mon. on or not. I've tried to
  • save with input mon. on the print track, quit, restart the CPU, open the session
  • save without input mon. on the print track, quit, restart the CPU, open the session
Then I think it's when I leave PT open and idle overnight with input mon. on that is the culprit, because when that happens I have to (force) quit PT, restart the CPU, open the session again, and that's when I get the error message.
Old 12-17-2010, 08:04 AM
I have the studio in my house, so I often choose to leave everything on so I can get right down to business in the morning. Besides, the gear keeps the control room so warm and cozy.
Old 12-17-2010, 08:50 AM
Sean Russell Sean Russell is offline
I've never trusted walking away from PT for more then a few minutes. Too many potential 'force-quit must restart' situations, not unlike what you're descirbing.
Gear, yes, PT Session, no.
... but does it help the chorus?
Old 12-17-2010, 08:58 AM
Really? Don't think I've had any issues before, but like I said, I've just started leaving input monitoring on at all times. Other than that, I haven't changed my workflow at all.
EDIT: Also, it's not normal that I have to use 128 voices/ 4 DSPs in my sessions.
Old 12-19-2010, 08:41 AM
All is good now. Have had one session open for days with 128/4 and input monitoring on, and PT behaves normally. I've been informed that there's been several minor power/electricity dips a few days ago. Since I don't have all my equipment connected to a UPS, I believe this could be the culprit.
Monitoring input and track during playback simonyeah Post - Surround - Video 5 09-24-2012 03:07 PM
Input Monitoring: What if you ONLY want to hear playback? EricWillhelm Pro Tools 10 2 10-21-2011 11:05 AM
Monitoring your input during playback with DIGI002 stevethrewup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2007 04:08 PM
help!!! why no spdif input when selected in playback engine??? Mike F 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-11-2001 08:42 PM
monitoring input with playback brothers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2001 10:45 PM
