Old 02-10-2021, 04:10 PM
Dfrerichs Dfrerichs is offline
Default C24 power supply voltages
Hi does anyone have the power supply service manual or know the voltages? I' read 57v on the 52v leg could this be an issue? On my console none of the analog input pre's are working and the output section is not working. The outputs all have a hum and thumping sound and the input pre's although they will clip when bringing gain up nothing is shown on the meters either on the control surface or within protools so I'm looking for any insight that I can find.
Another finding is the +21v leg reads -21v and the +21v is reading -21v. (according to the labeling on the circuit board inside the desk)
Thanks
Old 02-10-2021, 04:24 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: C24 power supply voltages
All I know is replacement C24 power supply is ****ing expensive. I also have C24 and once wanted to buy spare PSU because I am using that board on live gigs, but with those prices I chose to take my chances and mix with mouse in case PSU fried at the worst moment
Janne
Old 02-22-2021, 12:50 PM
I was able to borrow a brand new PSU from a friend for testing and the control room outputs still just make a thumping noise and the inputs are,'t fully working. With a mic plugged into any of the 16 input channels and when turning the input gain up I can get the overload light to clip but there's no metering on the console or in protools when the track is armed. Does anyone have a service manual for the Cl24 since I've now ruled out that it isn't a power supply issue.
Thanks for any help out there!
Old 02-22-2021, 01:34 PM
JFreak's Avatar
You may have better success by ignoring the mic pres and buy externals. Even cheap ones (sub thousand for eight channels) are better than built in. Of course you need extra cabling, but taking that console to service may be very very costly
Janne
I need a BIG 6 pin from cpu power supply to small 6 pin HDX power will this work recordingfun Pro Tools 12 1 04-05-2018 09:23 PM
Digi 002 Power Supply Molex Pinout Voltages frets70 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-28-2013 01:24 PM
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
