Old 05-29-2010, 09:32 AM
robo6675 robo6675 is offline
Default Noisy 192 input card
I've got a noisy input card on one of my 192's. Even when there is no DB25 cable plugged into it, 2 inputs consistently hiss and pop. I've tried working the ribbon cable connections and I can see no obvious flaws on the card.
Thoughts?
Thanks in advance!
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 05-29-2010, 10:22 AM
Tweakhead Tweakhead is offline
Default Re: Noisy 192 input card
Sounds like the card needs replacing.
Is this a brand new card, or have you been using it for a while?
If the latter, is your 192 well vented? They do not like closed-side racks I have found, as they vent from right to left. Any constriction to air flow can cause the unit to overheat, and once the AD or DA card overheats it can start exhibiting the anomalies you describe. It will then need to be replaced.
Old 05-29-2010, 10:32 AM
studiojimi's Avatar
studiojimi studiojimi is offline
the AVID exchange program is fairly affordable
might as well get it over with
i put mine off for a long time and sure was glad i got my input #4 back
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 05-29-2010, 10:52 AM
Yeah, they have had regular use for for a couple years now. And your probably right about the ventilation. It has blockage on one side. Right to left from which perspective?
Well what is broken, must be fixed...how do I go about this AVID exchange program?
Thanks for the replies guys.
Terrarium
Old 05-29-2010, 11:42 AM
studiojimi's Avatar
call tech support
CAZADOR RECORDING
Old 05-29-2010, 06:16 PM
oh that'll be fun...=)
Terrarium
Old 05-29-2010, 07:36 PM
studiojimi's Avatar
oh they'll be happy to take your dough.
i wonder if the HD cards are back-ordered that an exchange plan takes long now
CAZADOR RECORDING
Old 05-30-2010, 07:10 AM
SNIP... And your probably right about the ventilation. It has blockage on one side. Right to left from which perspective?
When viewed from the front of the unit.
Old 05-30-2010, 07:15 AM
Ah yes, it is definitely blocked on the right side.
Thanks for the input guys! This is what the DUC is all about.
Terrarium
Old 06-23-2010, 01:02 PM
Hey guys, another questions on this topic...
I found the digi tech support number but I really don't want to pay 2.50/minute for them to confirm that the card is bad. Anyone know of a more direct way to inquire how much it would cost to get it exchanged?
FYI this is way past warranty and I have no idea if it was registered as it was installed a couple years before I even started working at this facility.
Terrarium
Digidesign 192 Analog Input Card and Analog output Card for Sale MusicEngineer Buy & Sell 1 03-03-2014 09:03 AM
192 AD Expansion Card Noisy Channels dexter808 Pro Tools TDM Systems (Mac) 6 03-22-2007 01:44 PM
Noisy input fix? Help a n00b with a session! tdellaringa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-04-2006 06:46 AM
External talkback mic input low level and noisy nerdlinger ICON & C|24 2 08-24-2005 02:27 AM
Sound Card Input, HELP!! DigiCharles Digidesign Hardware & Software 2 11-24-2000 12:58 AM
