Old 12-10-2020, 10:41 PM
DrewHarrison DrewHarrison is offline
Default Matching Alternates - Keep Time Position?
Is there a way to use the Matching Alternates feature to swap out a file with a different version while maintaining it's time position on the timeline?
When I try the Matching Alternates feature it moves the new file to start at the beginning of the start of the clip, instead of its original time position.
Often I need to swap out a file with a different version after doing a lot of splice editing, fades, clip levels, etc. Can I keep all of that and just change the file only?
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-11-2020, 02:53 PM
Default Re: Matching Alternates - Keep Time Position?
Speculating on options:
1-look for an option to SPOT(so you could SPOT to the same timeline point)
2-create a new playlist(or several) and drop the alt clips on separate playlists(and SPOT to the same timeline position)
Hopefully, someone else has better options
Matching Alternates Using User Time Stamp - Not Working? DAWgEAR Pro Tools 2020 1 07-28-2020 02:14 PM
Missing Clips in Matching Alternates list dB-Pro Pro Tools 12 0 01-22-2018 12:01 PM
Indexing MXF Files and matching Alternates in PT11 synkope76 Post - Surround - Video 8 11-20-2013 02:27 AM
Pro Tools 10 no CTPK matching Alternates Matze1985 Post - Surround - Video 1 07-11-2012 12:52 PM
matching alternates doesn't work in PT9? tools macOS 3 09-07-2011 12:28 PM
