Old 09-24-2020, 01:42 AM
Default Known plugin conflicts
Plugin conflicts can take weeks or months to track down, a useful repository of these would be helpful. I'll try and keep the list in the OP up to date.
iZotope RX Connect (any version) and Native Instruments Kontakt (any version)
Causes crash when loading most nkis in Kontakt. Only workround for now is to close RX Connect from AudioSuite before loading a new instrument in Kontakt. NI are aware of the issue.
(Reported in all versions of PT up to 2020.9.1)
iZotope RX 7/8 (in AudioSuite) and Sonnox Oxford Drum Gate (higher than 1.0) and other Oxford plugins
Fixed in latest build of Oxford Drum Gate, being worked on for other Oxford plugins.
Any iZotope RX7 plugin and GRM Tools
Causes crash if GRM Tools is inserted anywhere in the session and RX is in Audio Suite
Opening any RX plugin causes crash. Both companies aware of the issue.
(Reported in all versions of PT)
Guy Rowland
www.guyrowland.co.uk
PT 2020 Ultimate; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Old 09-24-2020, 02:31 AM
Default Re: Known plugin conflicts
Made this sticky. Now just everyone please post your findings... also bear in mind what you post does not need to be reproducible on other systems (sometimes it is not) but anything that you think others would find good to know.
Old 09-24-2020, 11:20 AM
Thanks v much Janne.
Just updated to 2020.9.1 today, no change to the RX Connect / Kontakt crash.
Guy Rowland
Old 09-24-2020, 10:37 PM
massivekerry massivekerry is offline
Switching an Insert from an Instance of Komplete Kontrol to one of Kontakt.
Locks up every time. I haven’t filed any bug reports. I probably should. I just purged KK from my template, but I had to open some sessions from those dark years recently, and I forgot about that bug, much to my suffering.
Kerry Smith
http://apothekerry.com
12-core 3.46GHz Cheese Grater, 64GB RAM, HD | Native, HD I/O
Old 09-24-2020, 11:31 PM
Roll Roll is offline
Opening a rx7 audio suite plug-in, when a GRM tools is in insert on the session ...
Old 09-25-2020, 02:24 AM
I just tested this here and it worked ok in 2020.9.1, latest versions of KK and Kontakt in Win10. Can I just check I'm following the right steps? This is what I did
1. Insert Komplete Kontrol on an instrument track, load a patch
2. Replace KK with Kontakt, load a patch.
Guy Rowland
Old 09-25-2020, 02:28 AM
Thanks Roll - Mac / Windows? Any particular version(s)?
Guy Rowland
Old 09-30-2020, 10:38 AM
StudioRhythm StudioRhythm is offline
Thanks for starting this thread, Guy!
I heard back from Sonnox Support yesterday and can confirm that there's a new version of Oxford Drum Gate (v.1.05) that solves the iZotope RX7 AudioSuite crash problem.
In the process I did discover that the current versions of Oxford Dynamic EQ, Inflator and VoxDoubler all suffer from the same bug though. Sonnox says they'll all be fixed soon, within weeks.
www.studiorhythm.com
Old 10-01-2020, 01:32 AM
Good news, have updated - thanks!
Guy Rowland
Old 10-01-2020, 08:19 AM
daeron80 daeron80 is offline
Curiously, there's not a conflict between Sonnox SuprEsser and RX. Been using those together on both Mac and Windows for years.
David J. Finnamore
Nyquist was right.
PT 2020.11.0 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
HD TDM / Quicktime conflicts... Codo Pro Tools TDM Systems (Mac) 5 06-24-2012 08:29 AM
CPU Conflicts Siegfried Meier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-08-2007 11:48 PM
PT and Rhapsody Conflicts TMitchJobe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-03-2006 07:13 PM
Plug-in conflicts grobb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2003 10:48 PM
Known Extension conflicts! Dan L General Discussion 8 06-10-2001 01:18 AM
