  #21
Old 02-10-2020, 03:41 AM
Default Re: PT7.3 and TRacks24 issue...Need advice
Originally Posted by GMP View Post
No, it just needs the correct serial number typed in to get the Authorization code. the correct serial number was typed in but it won't allow me to go to "Next" screen to enter Digital ID and get the Authorization code.
Any advice is appreciated.
Are you running any script blockers? Accepting cookies? Also some of these schemes are sensitive if you use caps lock instead of the shift key when typing in upper case letters. Might also be case sensitive. Just checked and IK s/n's are all upper case. And don't confuse zero with the letter o.
  #22
Old 02-10-2020, 05:36 PM
GMP GMP is offline
OK, SUCCESS!!..turns out my IK tech guy wasn't sending me the correct serial number....So I was finally able to Re-register my TRacks24!!!!
but now a new problem , I get the code -6104 (cpu audio usage) blah...WTF is THAT all about??
MacPro Quad Xeon 64 Tiger 10.4.9/ 2.66 Ghz / 32GB RAM / ProTools LE 7.3 /MBox2/ T-Racks24 / Motif 6 /
ASR10 / Rokit 8's / Audio-Technica mic / AKG C3000 mic
GMP
  #23
Old 02-11-2020, 05:11 AM
Do you get the error when using the TRacks24 in a session? If not try moving the plugin to the unused plugins folder and see what happens.
  #24
Old 02-18-2020, 05:17 PM
GMP GMP is offline
I will try that too...but yet ANOTHER issue just popped up...Now PT7 will not convert my tracks to wav. during "Bounce to Disk" so I can Master them.....
Any advice on that?
This is turning into a REAL Nightmare guys...
GMP
  #25
Old 02-18-2020, 09:26 PM
So what file format your session is using? Bounce does the same file format. Say you are bouncing AIFF it is almost the same as WAV so when you create a new session for mastering you should be able to easily import your bounce.
  #26
Old 02-19-2020, 04:51 AM
Any advice on that?
Now I don't know if your version of bounce is real time or not but if it is you could always go old-school and route and record the output of said track to another audio track.
  #27
Old 02-25-2020, 07:10 PM
GMP GMP is offline
Still not converting. there's gotta be something I can do. Have you ever heard of this happening before with Pro Tools? not converting files to wav or Aiff? should I reload Pro Tools? that sounds like a bad idea but I'm getting desperate man. any help is appreciated.
GMP
  #28
Old 02-25-2020, 07:12 PM
GMP GMP is offline
I usually bounce to a wav file so I can Master it in TRacks24
But now when I try to "bounce to disk" the system will act like it's doing it, but when it's done, I can't find it in the folder I sent it to. like nothing there. at all
GMP
  #29
Old 02-25-2020, 07:15 PM
GMP GMP is offline
the issue is the coverting to wav or AIFF. my PT7 is not converting the tracks at all. they remain ptf files. it's so weird. I can't see any wav or aiff or mp3 when I "bounce to disk"...it's lilke they are hidden somewhere and going to that folder. but that's impossible because I tell it where I want it , it's just not there in the end.
and yes, I bounce in real time. I can hear the track as it bounces
GMP
  #30
Old 02-25-2020, 07:19 PM
GMP GMP is offline
the error comes and goes. it's weird. some times it's all the time, other times it's not popping up at all. it's weird.
GMP
Any advice for Waves license issue? mesaone AAX Plug-ins 18 04-18-2014 02:35 PM
MXF corruption issue PT 7 need experienced advice tvjordan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-17-2010 09:54 PM
Issue with new i7 build... need some advice. JamJuice Pro Tools M-Powered (Win) 5 09-22-2009 09:43 AM
How to use IKmultimedia TRacks24 stand alone K Roche 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-23-2007 04:21 PM
001 compatability issue? need advice... kunal781 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-27-2006 11:34 AM
