Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 10-18-2019, 05:55 AM
Sebastian_SAE Sebastian_SAE is offline
Default Recommendations for a interface that works well with PT
I'm looking for a Interface that has a good quality Headphone Amp and works well with PT. My price range is around 300$.
I tried using a Fiio E10K since i only use my PC for editing and mixing, however there is a lot of lag (play/pause/switching solo)
probably because of the Fiio (cpu/ram never above 60%).
Is the DAC/Headphone Amp in a Scarlett 2i2 / Presonus 26c comparable to the Fiio? (Headphones: 990/770pro 250 ohm)
Appreciate your input :)
Old 10-18-2019, 07:53 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Recommendations for a interface that works well with PT
Focusrite interfaces have good drivers and generally sound good.
If you can go a little higher, I would go for their Clarett series of interfaces, which sound very good. Something like the Clarett 2Pre would work well and you can sometimes find demo units right around $300. If you go that way, just make sure you get the USB version as they make Thunderbolt versions too.
Will K
System Details
Old 10-20-2019, 05:15 PM
With 250 ohm headphones, you may find many interfaces yield low volume
Old 03-24-2020, 09:32 AM
nedorama nedorama is offline
used Focusrite Scarlett (or b-stock) with as much IO as you need. I have the 3rd Gen 18i20 I bought as B-stock from Focusrite. Headphone outputs happily drive a pair of AKG K702's, so you should be fine.
Regards,
Ned
Monkey Boy Studios
2013 15" MBP, 16GB, 512GB SSD; OSX 10.15.4; 1.5TB FW800 External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2020.3
Plugins, Virtual Instruments, and real ones
Old 03-24-2020, 10:11 AM
Originally Posted by junkgear View Post
Clarett 2Pre
That is a great little box!
Apogee Symphony IO now works as USB interface nst7 Pro Tools 9 2 09-03-2011 09:35 PM
Pod XT as a PT 9 Interface - works. acmost macOS 6 12-31-2010 04:42 PM
pt only works when i only have hd and interface on the mobo chazzo03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-14-2008 05:29 PM
midi interface USB for Laptop what works? djd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-23-2005 08:08 PM
MIDI Interface that works with Digi 001? Reg. MIDI 4 10-10-2005 02:45 AM
