Old 08-19-2019, 10:18 PM
adam79's Avatar
adam79 adam79 is offline
Default MDW Hi-Res Parametric EQ 5
I was reading about the MDW Hi-Res Parametic EQ 5, but then learned that there's no demo and it's like $600! How is this plugin compared to other EQ plugins out there that are WAY less money?
Also, I found it interesting that when listening the instances, they go up from 48 to 96hz. Is this because the plug is working more efficiently at 96? I've found this to be the case with mostly everything, which really screws me on my UAD interface, which is just a DUO. I've found all plugs to sound better and work better at 96 than 44.1 or 48.
Thanks.
Old 08-20-2019, 05:20 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Default Re: MDW Hi-Res Parametric EQ 5
Dont buy the MDW EQ from Avid, the plugin is still corrupt, bouncing a song with 1 of this plugin in the session gives me a hard pop or click in front of the bounced file.
Its been this for years now and it seems they dont care...
(im on ultimate 2019-6 but it was also in previous versions of PT)
I know UAD has the same plugin, but I dont know about theirs... I didnt want to spent another dollar on a plugin I already own.
Johnny Hulst
Hulst Audio Engineering
MacPro (late 2013) 3ghz 8-core, 32gb Ram, 512gb SSD
1x Avid HDX & 1x UAD-2 Octo --> Sonnet Echo Express III-D
2x OWC PCI Express SSD (2TB) --> Sonnet Echo Express SE II
1x MTRX+MOM+1DA-card+SFP/LC module multimode 1300nm low output LED
4x 192 I/O (64 analog inputs)
1x HD Native Thunderbolt
Avid Artist Mix
Rupert Neve RNHP
http://www.hulst.nu
Old 08-20-2019, 05:25 AM
Thanks.
Why are you looking at the aax dsp version? The aax native version is only $299.
I don't understand your second paragraph. Listening the instances? What? The only reason some plugins sound better at 96 KHz (if they really do) is because of oversampling inside the plugin to get away from any possible aliasing from working at 44.1/48 KHz. That oversampling inside the plugin has nothing to do with your interface. There's no reason that I know of that a plugin would work better at a higher sample rate; might sound better/different but work better?
Old 08-20-2019, 09:20 AM
BScout BScout is offline
Find the link to the betas in these forums. The developers have fixed this in the beta a while back. They posted links in the forum (there are betas for both AAX-DSP and AAX, Windows and Mac; make sure you get the right one that matches your ilok license). So far two betas have been posted (obviously you want the latest which I think ended with “R11” and was posted sometime in spring 2019)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-20-2019, 03:31 PM
Thanks, have just downloaded this R11, going to try it tomorrow, very strange to put the link only here at the duc.
I could not care anymore with MDW, it took too long.
Happy heavy user now of the ssl duende x-eq, my new eq friend 😁 for 2 years now.
Johnny Hulst
Avid Artist Mix
Rupert Neve RNHP
http://www.hulst.nu
Old 08-20-2019, 03:34 PM
adam79's Avatar
Auto correct.. when the instances are listed in the specs. You can run more at 96 than u can in 48.
Old 08-20-2019, 04:18 PM
I don't think so - more at 96 than 48. Got a link to what you're looking at?
Old 08-22-2019, 02:12 AM
Wel, it seems my system thinks the beta is not a valid 64 bit plugin and asks me to remove the plugin from the pluginfolder
Well I just deleted it. Bye MDW
File Type: png Schermafbeelding 2019-08-22 om 10.07.28.png (26.3 KB, 0 views)
Johnny Hulst
Avid Artist Mix
Rupert Neve RNHP
http://www.hulst.nu
Old 08-22-2019, 08:01 AM
TOM@METRO's Avatar
It works fine here.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 08-22-2019, 08:39 AM
Originally Posted by TOM@METRO View Post
It works fine here.
Well on a pc or 2019-5 maybe, on my mac with majove and 2019-6 not.
Johnny Hulst
Avid Artist Mix
Rupert Neve RNHP
http://www.hulst.nu
HTML code is On
WTB: MDW Hi Res Parametric EQ jsvalmont Buy & Sell 2 03-02-2018 11:14 PM
Go-to Parametric EQs PatriotsBiker AAX Plug-ins 47 06-08-2016 09:44 AM
MDW Hi-Res Parametric EQ v5 is now available Avid Technical Alerts 1 08-24-2012 01:55 PM
parametric output EQ krishkrasj VENUE Live Sound Systems 1 05-10-2010 01:48 PM
What is Q in a parametric? dummy20707 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-22-2002 09:03 PM
