  #91
Old 07-27-2019, 09:12 AM
ghostwriter's Avatar
ghostwriter ghostwriter is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
FYI: The Crest adapter with the SSD drives are installed and working. Having a bit of a time getting the Mac OS onto one of them, but I will get there.
A few of of my favorite toys: Retro Instruments 176 (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM 70, SPX90, Roland SDE 3000...
  #92
Old 07-27-2019, 11:54 AM
arche3's Avatar
arche3 arche3 is offline
Awesome!!!!!
Sent from my SM-G975U using Tapatalk
  #93
Old 07-28-2019, 09:09 PM
rballister rballister is offline
As I have a Mac tower too I was wondering what sort of problem you are having with Mojave. My ProTools drive is already running as Mojave on an internal SSD. I use Superduper to back it up to on an external drive (bootable). My plan would be to just clone it back to the new NVMe drive if I go down this road (I'm presuming that's possible).
  #94
Old 07-29-2019, 02:28 PM
I am doing a fresh install of Mojave on one of the ssd drives, but it was not letting me update the firmware. I figured it out though. TURN OFF THE AVID PROGRAM. Days of banging my head against the wall and spewing expletives and that was the issue. I think I actually looked like my avatar.
Still can’t get Mojave to load onto the ssd drive, but I have High Sierra loading onto it as I type this. Hoping it will boot from the ssd drive and then I will update to Mojave. I will keep you all updated.
  #95
Old 07-29-2019, 08:34 PM
The Eagle has landed!
Mojave installed on SSD drive 1 in the Crest adapter and starts up perfectly.
SSD drive 2 is showing up fine too.
Tomorrow I will do some speed tests to compare with the one I did before upgrading. Plus, I will install Pro Tools.
  #96
Old 07-29-2019, 10:52 PM
arche3's Avatar
Great to hear!
  #97
Old 07-30-2019, 09:52 AM
SSD Drive Speed Test - Read: 2800
Old SATA Drive Speed Test - Read:118
  #98
Old 07-30-2019, 11:42 AM
But how does it make you feel?
What about boot time. Impact on Pro Tools startup. VI load etc.
  #99
Old 07-30-2019, 12:47 PM
Part of the time the computer freezes and won’t even let me shut it down when copying large or multiple PT sessions between SSD drives. But, not all of the time. Copying smaller files between SSD drives works fine.
Not sure what is going on there.
But, it sure boots fast, faster then fast, OMG fast.
  #100
Old 07-30-2019, 02:12 PM
I just moved 168 GB from an SATA drive to SSD drive 1 and it worked. The same file that locked the machine up earlier.
But, the machine locked up as soon as I tried to copy the same file from SSD drive 1 to SSD drive 2. SSD drive 2 doesn’t seem to like large files.
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 08:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 04:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-23-2018 12:47 AM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 05:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 03:02 PM
