Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 05-14-2019, 10:18 AM
@tention @tention is offline
Default Re: 2019.5 OLED not responding properly
That did not help, the display on the OLEDS is still very jumpy when performing pans and fades. The actual automation written is smooth, though.
SOUND!
Old 05-14-2019, 10:52 AM
EddieJones's Avatar
Originally Posted by pavoni View Post
Eddie - you may be asking specifically about the S3 - but on my Artist Mix where the OLED labels don't update - changing a plugin parameter works correctly - and the label then seems to update to be correct.
Great..you have the issue we can see here and are working to fix.
Old 05-15-2019, 08:07 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
same issue here - hope its sorted soon, basically unusable at the moment for me in my workflow
http://www.ainsliegrosser.com/
2013 MacPro 6 x 3.5 32GB OS10.14.4 HDX2 Sonnet Chassis, PT2019.5. Macbook 2018 Watch this to follow mobile mix studio build coming: https://youtu.be/cbqMTjCVj9I
Old 05-15-2019, 01:53 PM
ha2dorff ha2dorff is offline
S3:
This is a huge problem, so I really hope there will be a fix very soon.
I don’t know if it’s mentioned here, but after touching a fader and the volume is displayed, it do not return to normal view. To do that, I have to touch select.
Old 05-15-2019, 02:09 PM
EddieJones's Avatar
Originally Posted by ha2dorff View Post
S3:
What are your Fader Timeout Value settings set to ?
Old 05-15-2019, 03:16 PM
ACECOM ACECOM is online now
19.5.1 when?
Old 05-15-2019, 03:18 PM
EddieJones's Avatar
Originally Posted by ACECOM View Post
19.5.1 when?
We are trying to get it out ASAP, hopefully before the end of May. We have already resolved a couple of things.
Old 05-15-2019, 03:22 PM
Thanks for the answer Eddie.
Old 05-17-2019, 08:54 AM
AINSLIE's Avatar
https://youtu.be/uh2-LCd8S7U
detailing the OLED refresh issue bothering me the most - a 1 min video.
Old 05-17-2019, 10:31 AM
reichman's Avatar
reichman reichman is offline
For the skittish among us, is this issue only being seen under Mojave? I haven't moved to 2019 EuCon yet...
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
OLED eq graph Macsearcher Pro Tools | S3 9 10-26-2018 02:02 PM
OLED brightness RogerPaolo Pro Tools | S3 20 08-02-2018 07:29 PM
Artist Mix - text on OLED is cut off at the top Bul Artist Series 2 10-20-2012 09:40 AM
mc mix second channel 's OLED missing ! klyg Artist Series 2 10-10-2011 10:14 AM
