Dimmed solo button?
I have worked in Pro Tools for a long time but its the first time I noticed this. Solo button on one of the tracks are dimmed. Anyone knows?
Re: Dimmed solo button?
Are you using a Satellite Link? From the PT manual:
https://wanderingear.net Last edited by kelsey; 02-26-2019 at 05:17 PM. Reason: Looked closer at the picture. |
This is very easy to do accidentally - at least for me it is. Just command-click on the solo button and it should go back to "normal".
Reg
21.5" (Late-2015) 11,2 iMac i5 2.8GHz, 16Gb, PT 12.8.2, Metric-Halo ULN2 2d Exp'd w/Sierra 10.12.6 |
At first I also thought a track was solo-safed, but looking at the picture the dimmed solo button is yellow, not the dimmed grey that a solo safed track would be.
https://wanderingear.net |
you can solo a Track, which is in Solo Safe mode. Then its dimmed and yellow...
When I solo a solo safed track, the solo button is the same saturation of yellow as a non solo safed track. PT 2018.12
Is the dim solo appearing on a VCA? Your solo mode is probably in latch. If you solo the VCA and then a track which it is controlling, you get the dim yellow solo.
---------------------------------------------------- MacOS 12.4 / Pro Tools Ultimate 2022.4 |
Hi
Thanks for all replies. sry it took a while to respond. Yes its a dimmed yellow on a VCA so this is spot on: Quote:
Cheers |
New dock solo button lower then mute button | Sean Bombz | Avid S1, S3, Dock and Control App | 14 | 10-12-2017 06:05 AM |
Solo button | afarid | Pro Tools 12 | 2 | 04-05-2017 05:01 AM |
Is the solo button in PT LE REALLY this retarded? | FordVan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-04-2010 12:16 PM |
Solo button | blackbirdstudio | Pro Tools TDM Systems (Mac) | 5 | 01-29-2009 08:11 AM |
solo button of pT 4.3.1 | mr cawn | Pro Tools TDM Systems (Mac) | 3 | 07-10-2000 04:27 PM |
