Old 07-03-2017, 05:09 PM
slugblood slugblood is offline
Default Pro Tools 12 Screen glitch when loading plugins
Hi Everyone. I just downloaded Pro Tools 12.8 and every time I load up any of the plugins or virtual instruments that come with Pro Tools (AIR effects, XpandII), my session minimizes, all of the words are cramped, and everything looks glitchy. I've loaded up other VST plugins and they work just fine. Would love to have some help with this issue. I haven't found any help elsewhere. I've attached a picture of what it looks like when I load up Xpand II
I'm running on windows 10 on a Lenovo Ideapad Flex 4-1580
intel core i7-7500U CPU @ 2.70GHz
16G RAM
64bit operating system x64-based processor
Old 07-03-2017, 09:47 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default Re: Pro Tools 12 Screen glitch when loading plugins
Not seeing that and I'm on a windows system like you. What I do see in some manufacturers plugins is where the preset name should be (these are plugins I haven't given a preset name to) I get random characters which make a little sense somewhat... can't explain but the plugin settings are what they last were the last time I closed the session so it doesn't affect anything within the plugin. This is with older sessions I made on 12.7.1 and below.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 07-19-2017, 08:52 AM
Problem Fixed!
Hello anyone who is having this same issue, or screen glitches similar to this. Avid Support contacted me and they showed me how to fix it.
Here's what you do.
Right click Pro Tools icon>Properties>Compatibility> Scroll down and check the box that days "Disable display scaling on high DPI settings">Apply
Old 07-19-2017, 09:07 AM
TOM@METRO's Avatar
abc1mce2
Does this fix your issue as well?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-01-2018, 07:25 PM
federico federico is offline
Originally Posted by slugblood View Post
Problem Fixed!
Here's what you do.
Hi everyone. It did work, just some small changes in Pro Tools 2018. I'm using windows 10. I'm attaching a screen shot. You have to check the box that says Override high DPI Scaling behavior. Scaling performed by, and then select in the drop down menu: System.
BY the way thanks slugblood.
Old 02-01-2018, 07:35 PM
Well I thought it completely solves it but when you first upon any plug-in in a session it is almost out of the screen to the bottom and you need to drag it up. I think avid has to fix this. Thanks.
Old 02-02-2018, 12:31 PM
abc1mce2's Avatar
Originally Posted by TOM@METRO View Post
abc1mce2
Sorry for such a long delay but I never saw the message. The answer is I never tried it but another PT update after 12.7.1 (Don't remember which one) fixed the issue itself.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 02-02-2018, 03:18 PM
TOM@METRO's Avatar
Great!
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Pro Tools 10 won't get past loading screen rgp101 Pro Tools 10 7 06-05-2015 10:50 AM
pro tools 10 loading screen loads for 2 seconds and then disappears smokeybryant Pro Tools 10 0 07-03-2013 01:28 PM
Blue Screen After Loading Pro tools Help elsimiobionico 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-21-2012 08:49 AM
Grey screen crash on loading plugins... duckandcover Windows 14 11-07-2011 08:05 PM
Pro Tools 8.0.3 Won't Load. Hangs on loading screen kfoody Pro Tools M-Powered (Win) 3 01-03-2010 01:10 AM
