Avid @ NAMM 2018
Old 05-03-2017, 08:19 AM
TheNeil's Avatar
TheNeil TheNeil is offline
Default Application Manager Performance
So I know a ton of people manually uninstall or disable startup of the Application Manager due to its massive drain on system resources (I for one have removed it from my startup items); however, I quite like the app manager's functionality and would like to see it brought to a stage where it becomes usable.
Therefore, I've submitted an entry to IdeaScale for fixing this. Would appreciate if everyone in support of this can upvote accordingly.
http://protools.ideascale.com/a/dtd/...es/269199-3779
>100 Threads
>250 MB RAM
30-40% CPU usage on a 2.6GHz i7
...not acceptable for an always-on background updater IMO.
Thanks!
Pro Tools 12.8.3 (Non-HD) | macOS High Sierra | 2.6 GHz Intel Core i7 | 8GB RAM | 7200rpm SATA Drive | iLok 3 | Line6 POD UX2 | 256 Sample Buffer | 1 GB Cache
Old 05-03-2017, 08:38 AM
taylor4814 taylor4814 is offline
Default Re: Application Manager Performance
Done.
Old 05-03-2017, 08:39 AM
TheNeil's Avatar
Thanks!
I know it's questionable how much value an IdeaScale submission actually has, but worth at least getting it tracked somewhere.
Old 05-03-2017, 08:40 AM
TheNeil's Avatar
I'm also very much in support of the submissions for a setting to disable auto-start of the app too, but my submission is more focused around it behaving sensibly when I do open it.
http://protools.ideascale.com/a/dtd/...er/208602-3779
http://protools.ideascale.com/a/dtd/...rt/221432-3779
Old 08-13-2017, 02:34 PM
TheNeil's Avatar
So the description for the newly-released v17.7 of the App Manager mentions "...several stability improvements as well as bug fixes for high CPU usage and Sleep mode recovery."
Sounds promising.
Would be curious to get input as to whether anyone's seeing much of an improvement. I will be trying it out as well to see if they've made this a viable utility yet.
Old 08-19-2017, 11:57 AM
TheNeil's Avatar
Version 17.8 is still a steady 3.5% on a 2.6GHz i7, even when it's idle and no other Avid apps are running (not to mention a combined 300+ MB of RAM for it and the AvidAppManHelper).
A bit better, but still ridiculous.
How often does this damn thing check for updates!?
Everyone's going to continue hating what should be helpful application, unless it stops hogging key system resources.
Old 08-20-2017, 05:26 AM
v17.7, 17.8.... are these Mac-only versions? Not seeing any update to 17.5 in my Avid Application Manager on PC...
Old 08-20-2017, 05:30 AM
Never mind... no sooner had I posted that, than I received update alert for 17.8
Can't Log In to Application Manager Josh523 Pro Tools 12 Discussion 3 08-21-2016 08:44 AM
12.5.1 not available in Application Manager noeqplease Pro Tools 12 Discussion 13 06-21-2016 02:30 PM
Application Manager v2.5.5 Now Available DigiTechSupt Technical Alerts 0 05-09-2016 07:19 PM
Application Manager? jandue Pro Tools 12 Discussion 2 12-11-2015 01:05 PM
