Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 05-27-2013, 06:58 AM
Default Re: hard drives SSD?+ HDX + Win7 or MAC ?
Here
Go to post #2
It's really long, about 3/4 of the way through it are bios settings. These were from an older I7 but still hold true. The CPU speed and clock ratios will be different but everything else can be followed. Also be sure to check your ram speed is defaulted to your correct ram speed and the multiplier is not low making your ram speed slower than what it should be.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 05-28-2013, 12:48 AM
CLASS-A-DUDI TAMIR CLASS-A-DUDI TAMIR is offline
Actually, I sent a little "lost" is not my field ...
The question is: Is the current situation when I will be installing the HDX card and start working -
Is no changes except in - will be a problem or it simply allows more work "smoothly"?
If there was a video that demonstrates what needs to change and how, it was nice.
Old 05-31-2013, 04:31 AM
Finally some good news
Although I "snooze" ... :)
The delivery arrived (HDX - HD I / O 8X8X8) all mounted on a PC I assembled by computer help forum.
Everything works great without having to setup on BIOS ...
Just continue so, and now we wait for version 11.
Thank you all
Click image for larger version
win7 64 PTHD 9.0.1 hard disk optimization grendizer Pro Tools TDM Systems (Win) 0 01-30-2011 03:32 PM
Moved from Mac PPC to Win7 can't read ext drives-Solved GuyPicks Pro Tools TDM Systems (Win) 10 08-20-2010 11:57 AM
Win7 64 bit and HFS drives albee1952 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-07-2010 05:08 PM
Portable hard drives vs. desktop hard drives NHH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-02-2009 07:29 AM
SSD (Solid State Drives) Alleviating The Need For Two Hard Drives For PT? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 04-13-2009 12:19 AM
