Avid Pro Audio Community |
I'm working on a session for the first time since upgrading to HDX from my old workhorse PCIx HD4Accel rig. It's on a hex-core Westmere with 24GB of RAM, running 10.7.3 and 10.1.2
As a PT user since 1991, I'm a little perplexed. I was working on a sorta 'practice' session ... doing some mastering and messing around heavily with plugins to put this rig through its paces and acclimate a bit; lots of inserts going. Some Waves (S1 MS matrix and shuffler, MDW 3.0 Helios EQ, URS N series, Flux Bittersweet and Softube's Saturation. More than I'd typically use on anything in earnest, but many of these (outside of the MDW and S1 matrix/shuffle) are new to me, and I want to get an idea of what they do before going live-ammo with any of them. Anyway, at some point in the session, I started hearing crackling if my master fader was down at zero, but it would clear up when it was anywhere above zero. I checked clock cable, toggled between internal/wordclock ... still persisted. I figured it was worth a restart. So, I saved the session and restarted. Here's where it gets interesting. When I restarted, relaunched PT, and re-opened the just-saved session, the crackling behavior was gone, but so were all instantiations of MDW, and I think, one instantiation of Softube Saturation Knob. Now, it's not that the inserts in question were blank, mind you .. they were OCCUPIED BY DUPLICATES OF OTHER PLUGINS FROM OTHER INSERTS ON THE TRACK (complete with the same settings from their original instantiations). ie: On one track, there was an additional D3 DeEsser where the MDW should have been AND where the Softube Saturation Knob should have been, and on another track, there was a duplicate Softube Saturaton Knob where the MDW should have been. Perhaps it's noteworthy that I was using unlinked dual-mono versions (running in M-S between the Waves plugins) ... I dunno. But I can tell you, I won't be parting with my old rig anytime soon if I can't rely on Pro Tools to correctly save and recall my plugin assignments, let alone their settings. Especially in the case of the MDW EQ, this could cost me a TON of work, as getting the little cuts dialed in in M-S is probably the most critical thing I ever do with plugins. Thankfully, this thing can't disappear any of my analog gear. Has anyone seen this? I really hate being on the bleeding edge anymore. -Dave |
Continuing this as a monologue ...
Did a test this morning. New session, 2 stereo audio tracks. Audio 1:Save and close session. Reopen session, and now it looks like this: Audio 1:The problem only appeared on Audio 2, and this time, the duplicated plugin was the unlinked MDW itself (with the same settings as the other one). On Audio 1, with the linked instance of MDW, there was no problem; no plugin substitution. So .. seems maybe this is being triggered by unlinked multi-mono instances of MDW? Or somehow in combination? Note that I have also attempted this with unlinked Channel Strip (DSP) in place of MDW, and it too copies over the instance of the De-Esser above it. I then tried putting an unlinked Softube Saturation Knob in place of the D3 De-esser, and it got written over by a copy of the Channel Strip plugin below it as well .. It seems unlinked multi-mono is the problem here. -Dave edit: I have now tested this on earlier versions and 4 different Mac-based rigs, including non-HDX PT10 ... The behavior is consistent. |
I haven't seen that here but as an aside, things haven't been what they should be with unlinked multi mono plugs for many years.
On my old G5 HD3 accel PCI I found that unlinked 5.1 multi mono plugs by both Sonnox (the EQ) and GML would simply forget their settings. I ended up splitting the stems into LR LS RS .1 and C tracks for reliability. That was on tiger and PT 8.1cs2 I also used to do it on stereo overhead tracks and would find that my sonnox multi mono would have one side flat on reloading the session. Again I just split it onto mono tracks in the end. Not being able to trust these lead me to abandon multi mono unlinked plug ins back then. It's not exactly what your asking but I just thought I'd let you know my experiences with unlinked multi mono since way back on V8 It's also worth noting that saving an unlinked 5.1 GML as a preset then recalling it would also have the same undesired effect of not recalling anything but the setting on the top level of the display. Last edited by Neil Pickles; 04-29-2012 at 08:16 AM. Reason: further info |
Thanks, Neil.
Having made the jump from 7.4 straight to 10, I had no idea there were other issues with unlinked plugins. It's unacceptable, of course. But pretty disappointing too. FWIW, I've had a friend try the test I described on his HDX rig ... He was able to reproduce the exact same results consistently. I'm busy re-assembling my old rig so I can get some work done this week. -Dave ps: as for saving presets/settings from within the plugin, as you described, I think that when you unlink you actually have to save the settings individually for each and every channel. |
As I no longer use unlinked MM plugs since that V8 experience, I've been rocking away nicely on this HDX rig, so I won't be reassembling my HD3. I hope they get a fix for you soon. |
Out of curiosity does this happen in your backup sessions? So instead of opening your last "Main" session file... open the lastbackup... do the plug-ins still have issues?
I have had for years the issue of a Main session file (not regularly but upon occasion) becoming or saving corrupt data... the only way I have been able to get the session info back is the backup sessions folder... It seems more stable to "create a new session name (Each backup has a different name)" than to keep replacing your main session file. |
I'm hoping a solution comes quickly ... this is a showstopper here. -Dave |
Yes ,I tried it and got the same results
For anyone who was interested, Avid did confirm the bug I described, and a fix was included in the 10.2 update this past Tuesday:
Sessions saved in Pro Tools 10.0 or 10.1 with unlinked multi-mono plug-ins may open with the wrong plug-ins inserted (PTSW-163664) Whew! ... Onward! -Dave |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| AAX PLUGIN SHORTAGE, was it the same way the last time the format changed. | P,B,S | Pro Tools HDX & HD Native Systems (Mac) | 11 | 02-03-2013 10:16 AM |
| Re-opening former TDM session saved in HDX | stargazer | Pro Tools 10 Discussion | 5 | 01-22-2013 06:05 AM |
| Help, saved Pro Tools session changed/sounds different | Armando | Pro Tools TDM Systems (Mac) | 4 | 12-19-2012 01:57 AM |
| Changing track input/output assignments corrupts session files, causing PT to crash. | horribleheaven | Pro Tools M-Powered (Win) | 1 | 07-08-2010 10:47 AM |
| Can a 5.3 session recorded with HD system be saved as 5.1 session and opened on mix s | Ricky Cobble | General Discussion | 0 | 02-03-2003 01:10 PM |
