Avid Pro Audio Community |
#21
Thanks.
I did try what you suggested. Unfortunately setting the ram timing to the values that CPUID CPU-Z shows made things worse. I had to set it back to auto. Still freezes but not as much as manual settings. I didn't think I had to do so much teaking to get Native to work on my system. Especially since Mbox Pro and Pro Tools 10 worked so fine on the same system. Im not especially into tweaking bios, so It would help if someone with the same system as I have posted their excact bios setting for me to copy. Atleast the important settings.
Christian D ♫ http://chrisdee.bandcamp.com/ ⌨ |
#22
chrisdee,
You really should not have to do any tweaking. Our systems are very similar. I was running an 002rack on mine before HD|Native. I really didn't do much other than unplug the 002r, and install the native core card and plug in the Omni - and it just worked. I later updated firmware and later installed PT10 when it came out. The tweaks we are talking about should give your computer stability and speed. Can you post the settings from CPUZ from the ~600MHz column? Also, call Crucial and ask them if you can safely bump your memory voltage to 1.62 volts. Maybe you have an incompatible plugin??? Try pulling them all into the unused plugin folder and add them back a few at a time to see if you have a problem plugin. Greg
Intel i7 960 (Bloomfield), Gigabyte GA-X58A-UD3R (rev 1.0), 12 GB OCZ Gold 1600 ram, ATI Radeon 4650 (512 MB), an OCZ Vertex 4 (128 GB) OS drive, 2 WD Black 32MB cache 500GB Hard Drives in externally mounted drive bays for session storage, Win 7 x64, PTHD 10 Native, HD Omni, HD I/O 16x16 . |
#23
Im not completely shure yet but It seems like Pianoteq 4 is causing the freezes Im experiencing in Pro Tools 10.x.
Updating to Pianoteq 4 version 4.0.2 and disabling multicore rendering seems to have weed out the freezes in Pro Tools. Apparently multicore rendering in Pianoteq 4 can steal important CPU resources from Pro Tools causing it to freez/crash. http://www.forum-pianoteq.com/viewtopic.php?id=2268 Pianoteq forum admin says this is a Pro Tools problem. Is this correct ?
#24
CHRIS...DON"T KID YOURSELF AND SAVE YOUR EFFORTS! THIS PROGRAM IS FUNDAMENTALLY FLAWED.. Unfortunately you are at the mercy of Avid....Whenever they decide to release this fix and/or future versions that are solid and stable is when your issues will cease. I am sure that all of your other programs from other companies work swimmingly....
Showers Audio Productions (S.A.P. Studios, Boston, MA) MBOX 3 Pro Tools 10.3.5, ![]() Windows 7 64 Ultimate: SP 1 Dual M-Audio BX5 Monitors Intel Centrino Dual Core T6400 @2Ghz > 6GB RAM Corsair Force SATA 3 SSD internal /WD Passport Black external You've shown me darkness and now I thank you for the light... GO BRUINS! www.soundcloud.com/louieshowers www.youtube.com/louieshowers |
#25
Choosing another daw is not an option for me. Much time and money has been spent on Pro Tools and Avids hardware.
#26
FWIW, without the Pianotec plugin, I am running 10.0.1 on this same mobo, i7 920 cpu and 12GB of Kingston RAM(3 sticks in the white slots for proper triple channel operation). RAM timings set manually and its working quite well here
Gigabyte GA-EX58A-UD3R, Intel i7 950, 12 gig Corsair DDR3, PNY GeForce 210, Focusrite ISA428, Octopre Mk II Dynamic, Lucid GenX192, DIGI003 running PT10HD, Vintech and Five Fish preamps.............................. http://www.myspace.com/cswstudio www.capricornsoundworks.com The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to........... BTW, my name is Dave, but most people call me.........................Dave |
#27
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit | W8 RP 64-bit |
#28
#29
For some reason Pro Tools 10.1.2 and Pianoteq 4.0.2 is acting up again!
Its the same random freezes as befor. So I guess its still a no go! It a shame because Pianoteq 4 sounds so good.
#30
Raoul Crane
www.blaze-studios.co.uk PT 10.3.2 HD Accel 7, Windows 7 64 Bit, I7 960, Supermicro X8SAX, 2 x ATI FirePro V3700, 12GB Ram, Magma P7R464, Kingston SSD, 2 X WD Caviar Black, Triple Monitors |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Update for Gigabyte GA-EX58-UD3R users | albee1952 | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 40 | 03-25-2012 11:47 PM |
| Gigabyte GA-EX58-UD3R and hd system | dccarson | Pro Tools TDM Systems (Win) | 0 | 10-30-2011 02:45 PM |
| GIGABYTE GA-EX58-UD3R and HD Native + HD Omni ? | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 7 | 12-01-2010 04:10 PM |
| Pro tools HD and GIGABYTE GA-EX58-UD3R | KKalampo | Pro Tools TDM Systems (Win) | 4 | 04-07-2010 10:26 PM |
| if you have a Gigabyte EX58-UD3R motherboard please help me. | recordingguy | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 9 | 08-19-2009 08:09 PM |
