Avid Pro Audio Community |
Hello there,
I've brougth the elevenrack bundle with protools 10 and plugins. I've first installed protools and trying now to add some plugins AV Instruments files are download and set-up but when I launch Protools 10, no plugins can be found... The plugins files are in a *.big format (eg : boom.big). How can I activate these plugins ? Thanks Romain |
avi does not need activated. it is a part of pro tools. they might need to be installed seperately.
when you go to launch a plugin, NONE show up???
AKA: hOBODOM TRASHER Pro Tools Utility HD Native, Avid 16x16, Eleven Rack Intel I7 3930k Gigabyte x79 UD5 16 GB g skill ddr 3 1600 Nvidia 520 lots of drives... w7 64 |
hi guitardom,
That's the point i can't find out any plugins to assign as input for any track... neither in the audiosuite options. I've installed the AVI in the C:/.../AVID folder and i'm wondering if it should not be moved into the C:/.../AVID/PROTOOLS one. Any idea ? thanks |
These are vi's so they will not show up under audiosuite. ONLY in your plugin inserts on your channel strip. The .big files Are the instrument data for those plugins, not the actual plugin data. They default install to the correct spot and even if they do not, the plugin would still show up in your plugin inserts window. but the .big data files install into C:\Program Files(x86)\Avid\Avid Virtual Instruments. in here is a folder for each of the instruments.
If your on windows download my app from the link on my signature and extract it into your documents folder. Launch it and hit the "open rtas plug in folders" button. 2 folders will open, 1 for unused plugins and one for the used plugins. In the one for used plugins should be .dpm files for xpand2, boom, mini grand, etc. If so then they will show up in pro tools in your plugin inserts window. If that's the case, it's user error. If its not there it's an installer problem.
Bloody hell Steve, you'll put me out of a job.
Aaron Mulqueen |
Not as long as people are asking questions about silly things like lfo's, sine wave shapes, and moogs!!
Plugins are correctly found by you're nice app but i got two folders : one named commonfiles/digidesign/DEA and where plugins can be found and one named common files/avid where there's nothing exceptmidi devices and patch names sub folders.
I have tested something : I moved the plugins into ...common files/Avid folder and launched protools which had set them up but launched windows installer and failed... ![]() I removed the plugin and now PT's working well but still without plugins. Do you think I should re install PT10 ? Thanks |
the .big files for them go into the C:\Program Files(x86)\Avid\Avid Virtual Instruments and each in there own folder in the AVI folder. i think you might have move stuff around to much.... if any of these are not there it will not work properly. are you getting any plugins working like eqIII??? you are still not trying to find these in the audiosuite folder are you??? i am not sure of your experience level here, but i am curious if you are trying to launch the plugins from the correct spot?? in your mix window (window w faders) at the very top of the channel should be a heading labeled "Inserts A-E" and a set of rows below it where you click and select. the AVI will be under the "instruments" heading.
Aaron Mulqueen |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Arabic Virtual Instruments within PT10, help please | Eihab | Pro Tools 10 Discussion | 14 | 03-17-2013 10:32 AM |
| PT10 No stock instruments after install | LoneRider | Pro Tools Software (Win) | 6 | 10-17-2012 12:46 AM |
| Installing PT10 Virtual Instruments | kyoung91 | Pro Tools 10 Discussion | 2 | 02-21-2012 11:01 AM |
| Avid Virtual Instruments crash on PT10 | Kaze | Virtual Instruments | 6 | 02-13-2012 03:45 PM |
| Vitual soundcheck with MaxAir | wavem | System 5 | 1 | 05-27-2011 09:52 AM |
