Avid Pro Audio Community |
Trying to figure out how to monitor while using all 8 outputs on the 003. I have each output routed to a Summing Mixer with 8 inputs and thought all I had to do to monitor was have my speakers plugged into the Alt Output on the 003 with the Alt CR switch turned on. Not getting a signal this way and having to use the Main Output leaving me with only 6 outputs to Sum with. Am I not setting something up properly in the I/O Setup Window? Am I going to be limited to only 6 outputs if I want to monitor though speakers instead of headphones? Any help is greatly appreciated!
Get a monitor/source switcher(like the Presonus Central Station) and feed the summing amp outputs to the source selector. That way, you can easily switch between the summing amp and the 003 output. In any case, you need to monitor off the summing amp somehow. Or, route that back into the 003(assuming you will record to a "mix" track) and route the mix track to the 003 SPDIF output(the Central Station can also take the SPDIF output of the 003, so the 8 analog outs can all be used to the summing amp.
Gigabyte GA-EX58A-UD3R, Intel i7 950, 12 gig Corsair DDR3, PNY GeForce 210, Focusrite ISA428, Octopre Mk II Dynamic, Lucid GenX192, DIGI003 running PT10HD, Vintech and Five Fish preamps.............................. http://www.myspace.com/cswstudio www.capricornsoundworks.com The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to........... BTW, my name is Dave, but most people call me.........................Dave |
Why not just monitor through your summing mixer?
Does it not have monitoring facilities?
Just rockin'...what more is there? Bill in Pittsburgh |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 003 Monitor outputs | ThatArchieGuy | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 6 | 03-08-2010 08:07 PM |
| Monitor Outputs - 003R, Please help! | Benjamino | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 12 | 02-17-2009 09:02 AM |
| mbox 2 pro monitor outputs | cozy | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 1 | 04-02-2008 11:23 AM |
| Trouble with monitor outputs | tim_doyle | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 1 | 02-21-2005 08:00 PM |
| Monitor Outputs??? | Dinkus | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 1 | 04-09-2001 07:52 AM |
