Avid Pro Audio Community |
PT9, Windows 7 Ultimate Digi 002 Asus P6T, Intel i7 2.66ghz, 6GB OCZ DDR3, HIS 4650 ATI Chipset 512MB DDR3, OCZ Stealth Xstream PSU 700W, WD Caviar Black 500GB System Drive, WD Caviar Black 500GB Recording Drive, Seagate Barracuda 1TB Audio Storage Drive, Furman HDS-6, Presonus Central Station Plus,Tannoy Reveal Active, Mackie HR824mkII, Manley Dual Mono, MPTK, SSL 4000 Komplete 7 Roland Integra-7 Nord Stage Classic 73 Rev. C Nord Lead 3 Roland RD-300sx Alesis Micron |
Here ya go! First draft, haha.
http://www.mediafire.com/?djcznmdydtn It's kinda blah before 0:51 though. |
I just wrote the beat in Kinetic and cut out clips of the song and then arranged them in the desired pattern
![]() Like so: http://i39.tinypic.com/34yzo68.png Yay Pro Tools Working! Back on topic: FINAL SOLUTION: So disabling my High Definition Audio CODEC is the trick! It consistently allows PT to boot up with no problem. And when PT is done booting up, I can just enable the codec again! ![]() Thanks for all the help! |
Sweet!
i know you've solved your problem, but in case somebody else stumbles across this thread, i had the same problem on a fresh protools install last night. everything worked fine the first couple of times i fired up protools, then it started to give me a dae 6006 error at creating dae objects and closed. after backtracking on my software installs, it turned out to be the driver for my edirol usb midi interface (which worked fine on my former machine, also running windows 7 64 bit). i had to unplug the device and uninstall the driver completely...then everything was fine. haven't had a chance to explore further, but it's nice to have a couple of extra midi inputs so i hope to get to the bottom of it soon.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| freeze on "creating dae objects" | jloakland | Pro Tools TDM Systems (Mac) | 1 | 06-27-2011 11:29 AM |
| PT9, Win 7 64 bit & "Creating DAE Objects" freeze | The Bagwhan | Pro Tools Software (Win) | 5 | 12-08-2010 12:35 AM |
| Freeze on "Creating DAE objects" | gossamer | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 26 | 10-25-2010 08:46 AM |
| Pro tools 8 freezes at "Creating DAE objects" | babydolla1 | Pro Tools TDM Systems (Win) | 0 | 06-15-2010 02:44 PM |
| System Hangs on "Creating DAE Objects" In Vista 32 w/ Digi003 | Rostafunk | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 1 | 03-19-2009 01:18 PM |
