Old 07-03-2015, 06:45 AM
kava kava is offline
Default "Write to All enabled Shortcut" not working...
the shortcut is not working anymore. but works when selected from the menu.
this is VERY annoying.
http://protools.ideascale.com/a/dtd/231991-3779
Old 07-03-2015, 06:58 AM
Stig Eliassen's Avatar
Default Re: "Write to All enabled Shortcut" not working...
Confirmed. Details in my signature. I'll bring this along.
Old 07-03-2015, 07:15 AM
Drew Mazurek's Avatar
I'll confirm and log it ASAP.
www.drewmazurek.com
Old 07-03-2015, 08:29 AM
Southsidemusic's Avatar
Here aswell. Thanks for escalating this bug.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-03-2015, 08:37 AM
I haven't had a chance to personally check it, but I logged it anyway.
thanks.
www.drewmazurek.com
Old 07-03-2015, 11:32 AM
Danny Caccavo Danny Caccavo is offline
thanks.
Not seeing this problem. Is it possible that there is a new Apple shortcut that is stepping on command-option- forward slash? I usually have to uncheck some to get Pro Tools to be happy, like Shortcuts/Input Sources/Select the previous input source - that steals "command-spacebar" which I always use for record. I think Spotlight used to use that too.
Old 07-04-2015, 05:53 AM
I can't find any shortcuts anywhere that steals focus from PT. Actually, none of the automation shortcuts containing forward slash works here. However, if I just click on Edit so the drop-down window is open, then all of the shortcuts works.
I obviously use my console for mixing, so I haven't seen this before. Thanks.
Old 07-06-2015, 03:15 AM
Can't be an OS issue. I have a co-install of 10 / 11 / 12 here. shortcut is only working on 10 / 11, nothing steals from PT in this case.
Function IS also working on S6.
Old 07-06-2015, 06:29 AM
Can you describe exactly what you're doing? Reason I ask is, Command-option-/ is not the same as the Write To buttons on a control surface.
www.drewmazurek.com
Old 07-06-2015, 10:24 AM
I'm getting expected behavior here on PT11 and 12.
www.drewmazurek.com
Shortcut "Write Automation to all enabled parameters" on Mac Book Pro mecderue Pro Tools 11 5 10-06-2015 10:45 AM
"Write To Current" KB-shortcut missing Nicklas macOS 0 07-06-2012 02:27 AM
How is "Automation Write to Stop" working in PT 10 made Pro Tools 10 1 11-17-2011 02:53 PM
"write to all enabled parameters" shortcut not working Eric L Pro Tools TDM Systems (Win) 3 05-05-2007 07:49 AM
Looking for "Write to All Enabled Parameters" LE equivalent CCash Pro Tools TDM Systems (Mac) 1 05-15-2002 05:39 PM
