Avid Pro Audio Community (http://duc.avid.com/index.php)
-   003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) (http://duc.avid.com/forumdisplay.php?f=17)
-   -   Help!! trying to setup PT 5.3.1 (http://duc.avid.com/showthread.php?t=68117)
LATablette 10-29-2002 08:22 PM
ok, I downloaded the upgrade of 5.3.1 to my windows xp pc. when I try to open the file that was downloaded, I get a message saying the file cannot be opened without knowing what program created the file. The file has a .cfm extention but I don't know what that means. I can't see a .exe file. any help would be greatly appreciated.
Shamtown 10-29-2002 10:51 PM
Re: Help!! trying to setup PT 5.3.1
.cfm? do use a download accelerator like gozilla or get-right or something? if you downloaded the correct file it should end with .exe
The Electric Trombone 10-30-2002 01:46 PM
Agreed, you might want to re-download the file and see if you get differetn results.
Do you have broad-band of any sort ?
regards,
LATablette 10-30-2002 05:49 PM
turns out it was an exe file, but for some reason it had that different extention. When I renamed it with an exe extention, it worked fine. go figure.
