Need to use only Digi002 w/Mountain Lion
I do not have a need at the moment to use my Pro Tools LE software (which will need to be updated), but my Digi002 is the means of getting audio in and out of my computer, which is a new MacMini running Mountain Lion (OS 10.8.2).
What do I need to install in order to use just the Digi002 at this time? Thanks. |
Re: Need to use only Digi002 w/Mountain Lion
Just download and install the latest 002 drivers from the website. That will install the basic Core Audio driver which will let you use it with other programs, or with the system sound, etc.
Thank you, nst7!
Much appreciated. |
did this work?
I was just curious b/c it seems from what I understood from the website that just 10.7.4 was qualified for those drivers...... if it works that is great but just trying to find out....Thanks. |
Sorry for the delay; I was waiting for the delivery of a Firewire cable adapter, without which, I couldn't connect my 002. Thanks again, nst7! |
been a while since i posted in this forum, however ive had my MBP for almost a year and have recently decided to try and get my 002r to work with my MBP. i downloaded and installed the standalone drivers from the avid website and the audio manager doesnt seem to recognize my hardware. tried all 3 downloads and no luck. any ideas as to why? could it be that im on 10.7.5? itd be nice to use this interface so i have access to 16 ins/outs without having to use pro tools (not that it would work anyways) any info/help would be appreciated. thanks :D
edit: ignore the specs in the signature. i have a MBP Quad i7 2.2 GHz (late 2011), 16GB RAM, OSX 10.7.5 |
should work bro......
yea i would they would too, however like i said the core audio manager for the 002 doesnt even see the hardware. so there is no connection being made. i know the interface works as i powered up my windows system and was able to open up PT just fine. if it doenst work then so be it, however itd be a total waste as i dont wanna have to purchase another interface and i dont need to us PT.
Does your 002R show up in the Apple Audio MIDI Setup app in your Utilities folder? I don't know exactly what to tell you if it doesn't, but I would do a few things:
First, read do whatever is recommended by this troubleshooting post on the AVID board: http://duc.avid.com/showthread.php?t=54888 I might also try repairing permissions using Disk Utility. If that didn't help, I would then use the Pro Tools installer to uninstall everything and try again, installing ONLY the driver that is correct for my configuration. |
