very slow start up
Hello,
i had this issue with 8 as well.. when i launch Protools it takes a fairly lengthy amount of time to look for plugins and boot up . Once finshed loading it works fine.. If i shut the program down ..then load it up again, it loads super quick. Just wondering why this happens? Is it possible to speed up the initial launch? For my setup i have protools running of an internal drive but I am currently using a usb line for an external drive which i record audio onto. In the near future i will have another internal drive for the audio. I tried launching with or without this external drive and noticed no difference in terms of speed. SiSoftware Sandra Computer Manufacturer : HP Model : HPE-372f Family : 103C_53316J G=D Version : xxx0204GRxxxxxxxx0 Serial Number : MXX029020C ID : BE163B80-1015E556-2E8ECBA2-68FA9BB8 SKU Number : BK472AA#ABC Computer Chassis Manufacturer : HP Type : Desktop Can be locked : No Power Cord(s) : 1 Asset Tag : MXX029020C Boot-up State : Safe Power State : Safe Thermal State : Safe Security State : External Interface Locked-out Mainboard Manufacturer : MSI Multi-Processor (MP) Support : No Multi-Processing (MPS) Version : 1.40 Model : 2A9C Type : Mainboard Version : 1.0 BIOS : 65-0100-000001-00101111-051910-LfdHvdImc Mainboard Properties Removable : No Replaceable : Yes Hot Swap : No Computer Memory Controller Location : Mainboard Error Correction Capability : None Number of Memory Slots : 4 Maximum Installable Memory : 16GB BANK0 - DIMM0 : Samsung M378B5673FH0-CH9 4840B93A NONE DIMM Synchronous DDR3 2GB/64 @ 1.33GHz BANK1 - DIMM1 : Samsung M378B5673FH0-CH9 4840B931 NONE DIMM Synchronous DDR3 2GB/64 @ 1.33GHz BANK2 - DIMM2 : Samsung M378B5673FH0-CH9 4840B942 NONE DIMM Synchronous DDR3 2GB/64 @ 1.33GHz BANK3 - DIMM3 : Samsung M378B5673FH0-CH9 4840B9DF NONE DIMM Synchronous DDR3 2GB/64 @ 1.33GHz Chipset Model : HP Clarksfield/Lynnfield DMI OEM Device Name : Intel Clarksfield/Lynnfield DMI Revision : B2 Bus : Intel CSI (Quick Path) Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Maximum FSB Speed : 2x 3.2GHz (6.4GHz) In/Out Width : 20-bit / 20-bit HTT - Hyper-Threading Technology : No Maximum Bus Bandwidth : 18.7GB/s Maximum Power : 20.00W Chipset 1 Hub Interface Type : Hub-Interface Version : 2.00 Number of Ports : 4 Width : 16-bit Full Duplex : Yes Multiplier : 2x Chipset Model : Intel Core Desktop (Lynnfield) UnCore OEM Device Name : Intel Core Desktop (Lynnfield) UnCore Revision : A5 Bus : Intel CSI (Quick Path) Version : 1.00 Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Maximum FSB Speed : 2x 2.4GHz (4.79GHz) HTT - Hyper-Threading Technology : Yes I/O Queue Depth : 64 request(s) Chipset 2 Hub Interface Type : Intel CSI (Quick Path) Version : 1.00 Multiplier : 18x Speed : 2x 2.4GHz (4.79GHz) Logical/Chipset Memory Banks Bank 0 : 2GB DIMM DDR3 9-9-9-24 4-33-11-6 2T Bank 1 : 2GB DIMM DDR3 9-9-9-24 4-33-11-6 2T Bank 3 : 2GB DIMM DDR3 9-9-9-24 4-33-11-6 2T Bank 4 : 2GB DIMM DDR3 9-9-9-24 4-33-11-6 2T Maximum Installable Memory : 32GB Supported Memory Types : DIMM DDR3 Scrubbing Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Maximum Memory Speed : 2x 667MHz (1.33GHz) Multiplier : 5x Width : 64-bit Integrated in Processor : Yes Power Save Mode : No Fixed Hole Present : No Maximum Memory Bus Bandwidth : 20.78GB/s APIC 1 Version : 2.00 Multiplier : 1/2x Maximum Interrupts : 24 IRQ Handler Engaged : Yes Enhanced Support : Yes Memory Module Manufacturer : Samsung Model : M378B5673FH0-CH9 Serial Number : 4840B931 Type : 2GB DIMM DDR3 Technology : 8x(1024Mx8) Speed : PC3-10700U DDR3-1334 Standard Timings : 9-9-9-25 4-34-10-5 Version : 1.00 Date of Manufacture : August-26-16 Timing @ 457MHz : 6-6-6-16 3-22-7-3 Timing @ 533MHz : 7-7-7-19 3-26-8-4 Timing @ 610MHz : 8-8-8-22 4-30-9-5 Timing @ 686MHz : 9-9-9-25 4-34-10-5 Memory Module Manufacturer : Samsung Model : M378B5673FH0-CH9 Serial Number : 4840B93A Type : 2GB DIMM DDR3 Technology : 8x(1024Mx8) Speed : PC3-10700U DDR3-1334 Standard Timings : 9-9-9-25 4-34-10-5 Version : 1.00 Date of Manufacture : August-26-16 Timing @ 457MHz : 6-6-6-16 3-22-7-3 Timing @ 533MHz : 7-7-7-19 3-26-8-4 Timing @ 610MHz : 8-8-8-22 4-30-9-5 Timing @ 686MHz : 9-9-9-25 4-34-10-5 Memory Module Manufacturer : Samsung Model : M378B5673FH0-CH9 Serial Number : 4840B9DF Type : 2GB DIMM DDR3 Technology : 8x(1024Mx8) Speed : PC3-10700U DDR3-1334 Standard Timings : 9-9-9-25 4-34-10-5 Version : 1.00 Date of Manufacture : August-26-16 Timing @ 457MHz : 6-6-6-16 3-22-7-3 Timing @ 533MHz : 7-7-7-19 3-26-8-4 Timing @ 610MHz : 8-8-8-22 4-30-9-5 Timing @ 686MHz : 9-9-9-25 4-34-10-5 Memory Module Manufacturer : Samsung Model : M378B5673FH0-CH9 Serial Number : 4840B942 Type : 2GB DIMM DDR3 Technology : 8x(1024Mx8) Speed : PC3-10700U DDR3-1334 Standard Timings : 9-9-9-25 4-34-10-5 Version : 1.00 Date of Manufacture : August-26-16 Timing @ 457MHz : 6-6-6-16 3-22-7-3 Timing @ 533MHz : 7-7-7-19 3-26-8-4 Timing @ 610MHz : 8-8-8-22 4-30-9-5 Timing @ 686MHz : 9-9-9-25 4-34-10-5 Sensors 1 Model : Fintek F71858F/FG LPC Mainboard Specific Support : No Sensors 2 Model : Intel Core CPU [P0, C4, T99] Version : 30.05 Mainboard Specific Support : No Temperature Sensor(s) CPU 1 Temperature : 38.00°C td System Bus(es) on Hub 1 Version : 2.30 System Bus 0 : PCI System Bus 1 : PCIe 2.00 x16 5Gbps System Bus 2 : PCIe 2.00 x1 2.5Gbps System Bus 3 : PCIe 2.00 x1 2.5Gbps System Bus 4 : PCIe 2.00 x1 2.5Gbps System Bus 5 : PCI66 System Bus 255 : PCI LPC Hub Controller 1 Model : HP H57 LPC Interface Controller OEM Device Name : Intel H57 LPC Interface Controller Revision : A7 ACPI Power Management Enabled : Yes Advanced TCO Mode Support : Yes Advanced TCO Mode Enabled : No High Precision Timer Enabled : Yes Number of Precision Timers : 8 System Timer : 14.32MHz Delayed Transaction Enabled : Yes LPC Legacy Controller 1 Type : Fintek F71858DG Version : 0.07 Number of Enabled Devices : 16 Disk Controller Model : HP ICH8R (ICH8) SATA RAID Controller OEM Device Name : Intel ICH8R (ICH8) SATA RAID Controller Interface : SATA Revision : A7 Maximum SATA Mode : G2 / SATA300 RAID Support : Yes RAID Enabled : Yes Channels : 6 In Use Channels : 2 Port : G1 / SATA150 Port : G1 / SATA150 Audio Device Model : HP P55/PM55/3400 High Definition Audio OEM Device Name : Intel P55/PM55/3400 High Definition Audio Revision : A7 Type : HD (High-Definition) Audio Version : 1.00 Number of In / Out / Bi-Directional Streams : 4 / 4 / 0 Number of Serial Data Streams : 1 Audio Codec Model : Realtek Semiconductor 888 High Definition Audio Revision : A3 Version : 1.00 Audio Channels : 14 Audio Device Model : HP EG JUNIPER XT Audio Device [Radeon HD 5700 Series] OEM Device Name : ATI (AMD) EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Revision : A1 Type : HD (High-Definition) Audio Version : 1.00 Number of In / Out / Bi-Directional Streams : 0 / 1 / 0 Number of Serial Data Streams : 1 USB Controller 1 Model : HP P55/PM55/3400 USB2 Enhanced Host Controller OEM Device Name : Intel P55/PM55/3400 USB2 Enhanced Host Controller Revision : A7 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 2 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No USB Controller 2 Model : HP P55/PM55/3400 USB2 Enhanced Host Controller OEM Device Name : Intel P55/PM55/3400 USB2 Enhanced Host Controller Revision : A7 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 2 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No FireWire/1394 Controller 1 Model : HP VT6315 Series Firewire Controller OEM Device Name : VIA VT6315 Series Firewire Controller Revision : A1 Version : 1.10 Interface : OHCI Enhanced Support : No Speed : 400MHz SMBus/i2c Controller 1 Model : Intel 801xx/63xx SMBus Version : 0.06 Specification : 2.00 Advanced TCO Mode Enabled : No Slave Device Enabled : Yes PEC Support : Yes Speed : 100kHz Expansion Slot(s) PCIE-1 (1h) : PCIe x16 +3.3V Shared PME Full-Length Used PCIE-2 (2h) : PCIe x1 +3.3V Shared PME Half-Length Available PCIE-3 (3h) : PCIe x1 +3.3V Shared PME Half-Length Used PCIE-4 (4h) : PCIe x1 +3.3V Shared PME Half-Length Available Mini-PCIE (5h) : PCIe x1 +3.3V Shared PME Half-Length Available Performance Tips Notice 224 : SMBIOS/DMI information may be inaccurate. Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: very slow start up
Im finding the same problem here. Its taking me 5 minutes to start up for the first time. I reinstalled all my plugs, and I trashed the prefs. Not sure of what else I should do to make it start faster.
Why is this happening\?/////// |
This is normal!
it's only the 1st time and after this it should be fine. what's 5 mins to get a stable daw after that? Great excuse for a cup of java :D only after a plugin update it might take a bit longer again. cheers, Mark |
Hmmm... Every time I power on my computer it takes 5 mins to start Pro Tools, not just after a plugin update. Or are you saying its normal every time I start my computer to take this long? I dont remember 6.4 (the last time I had Pro Tools on PC) taking that long to start.
no, THAT is not normal.
Have you tried trashing all prefs? Quote:
Do you have tons of plugins? The initial slow loading time might be the re-authorization of everything because you deleted your prefs or installed upgrades to PT.
For example, I have the Waves Gold bundle and whenever I upgrade or crossgrade PT, the initial load time always takes significantly longer. As mentioned above however, after that, load time should greatly improve. Note, trashing prefs or modifying/deleting/upgrading PT files can also result in your slow load time first time around. PT will go through the slow 'first load' sequence each time its slate is wiped clean or rebooted. Anything after this...something be wrong friend. IMO |
Hi again. Yah, I tried trashing all the prefs, no difference. Weird. I dont have that many plugs (all legit, no cracks). I have maybe 10-15 plugs installed that arent the ones that come with Pro Tools. This is also a fairly fresh install of Windows 7.
I did some timings on the start up times: After restarting the computer: 1st Pro Tools start up: 4 mins 26 seconds 2nd Pro Tools start up: 38 seconds 3rd Pro Tools start up: 40 seconds I then restarted my computer and did the timings again: 1st Pro Tools start up: 4 minutes 12 seconds 2nd Pro Tools start up: 40 seconds 3rd Pro Tools start up: 39 seconds This was the time it took to get from clicking on the icon to the "Quick Start" screen. It does seem the first start up is scanning the plugs very slowly. When I first noticed this I went through and reinstalled every 3rd party plug with freshly downloaded installers (to make sure I had the latest versions) and trashed the prefs. I also did a fresh reinstall of Pro Tools. Any other ideas? Thanks for the help everyone, Michael |
This Is Normal ! :) I face the same situation .. and this only occurs with Pro Tools on a PC Based system never on a MAC !
PT 9 launches in seconds on my Macbook Pro which have much lower specs than my Desktop based PC and with the same plugins on both .... it takes from 3 to 5 minutes to load on my PC every time :) Cheers |
I'm experiencing the same problem (among others). I never had the problem on xp and pt 8. On xp it would take a long time to load ONLY after deleting prefs or adding a new plugin. Then it would take around 30 seconds every other time. NOW it takes at least 3 minutes to start EVERY time I first turn on pro tools after a restart. Definitely annoying. Would love to see this fixed.
