Installing 3.1 "killed" my MC Mixes
So Mac Pro 1,1 on OSX 10.6.8, I previously had V2.7.1 installed, and although connectivity was sometimes a pain (I would turn units on and off until they showed up), it worked. I installed 3.1, and since then haven't been able to get my MC Units to connect, they show up in the EuControl Settings on the left side as available, but they will not 'Add' to the 'My Surfaces' side.
They're set to Auto DNS on the units, with unique IP addresses, and Subnet 255.255.0.0 On the computer the subnet is set to 255.255.0.0 and the computer has a unique IP. These used to work fine, I've since removed v3.1, and reinstalled 2.7.1 and they still show up on the left, but won't 'Add' suggestions? |
Re: Installing 3.1 "killed" my MC Mixes
Hi
Are you sure Eucon 3.1 is compatible with anything under 10.7.5? Saw somewhere that 10.6.8 wasn't even on the list but can be wrong. Chris |
I'm not sure of that. Which is why I downgraded back to 2.7.1
