samplaire |
08-24-2011 08:49 AM |
Re: "this session contains media that is not supported by the video peripheral"
Originally Posted by DigiTechSupt
(Post 1826804)
Do you have any other devices connected to the firewire bus on the computer?
No, the only fw device is the mbox2 pro and on the 4 other machines there are mbox pros (the new ones) and canopus 110.
Which codec is used for the videos in these sessions? Do you notice any pattern with a particular codec causing the problem?
I encounter the problem on 2 codecs I use - it's DV PAL (mov made using QT) on the mbox3/canopus machines and photo jpeg (mov made using QT) on the mbox 2 pro machine. I don't know if other codecs lead to the problem because I don't use any other.
Do you have a video that will always cause the problem? If so, can you use a free file hosting service to upload it and post link (or send me and email at : vi [at] digidesign [dot] com) so I can check it out?
Unfortunately I see the message randomly, no specific movie...
