error 6086 with an mbox
Hello,
since i 've buy my mbox i' not able to play a session (even an empty one with out track inside!!) more than 10 secs i use to be on sp2 bur even with sp1 it's the same i also made carefully to all the possible settings for win xp i' ve got a "-6086 the operating sytem held off interupts for too long...blabla..." i increase also my buffer size to 1024.. nothing i also start my Win xp in "diagnostic mode" with out a minimal of service.. nothing i really don't know what else i can do this type of error seems to exist for a long time i've seen many people with this but may be some one has found the problem pliz help thanks for your advice David Ps here is my configuration Processor: AMD Athlon(tm) XP 2100+ 1.7 GHz Math Support: Present BIOS: AMIINT - 10 Version 1.00, 06/18/02 Bus Type: PCI, ISA, USB Ports: 1 Parallel, 2 Serial Memory: 768 MB (23% Utilized) Floppy Disks: 1,44 MB Hard Disks: 37,27 GB, 223,58 GB Multimedia: Sound, CD-ROM Video: 800 x 600 in 64K Colors, NVIDIA GeForce3 Ti 200 Ver. 6.14 |
Re: error 6086 with an mbox
Have you tried searching for the error in the Answerbase?
yes of course
they say to disable hyperthreading in the bios but i have have an atlon xp 2100+ hyperthreading is only for intel processor |
Ok for some peaople which are intrested
the problem was coming from my usb 2.0 port you should'nt plug your mbox on usb 2.0 port it's not comptatible with the mbox |
Uh, that's weird... I thought USB 2.0 could handle USB 1 devices
Anyway, thanks for sharing that with us. |
So David,
Where did you hear USB 2.0 is not compatible with Mbox? Was this information from Digi Tech support? I am just curious if this is a known problem, because I have searched for about 6 months now on Mbox related problems, and have not seen that discussed? I wonder what one would do if all ports on your computer are USB 2.0?? thanks, |
I used an Mbox on my USB 2.0 ports with no problem. 2.0 is backwards compatible with 1.1 and 1.0.
is it possible to use mbo 5.31 software on windows xp sp 2 if so what do i need to download because everytime i start protools it goes to a black screen and says the computer needs to be restarted. can you help?
I am having the same problem. I have a Pentium 4 Processor with Windows Xp and have yet to be able to play a complete song without getting the same error. Disabling Hyperthreading is not an option in my bios.
I don't think I have any USB 1.0 ports but I didn't think that would matter since I understand them to be backwards compatible. I am still looking for solutions. Any help would be appreciated. |
I am having the same problem, also 9129 and 9093 errors. But before a month or so ago everything was working ok for about a year, so this is more like a computer problem rather than a Digidesign flaw. I assume something changed in my system,registry, or configuration.
I've tried turning off the ethernet card, disabling firewall and virus software, and stopping a few services but so far no luck. Also trashed Digidesign databases (what are they for anyway?). Richard |
