Sends question
I know you can set a pref to have new sends to default at -Inf, but is there any way to simultaneously select say 50 reverb sends on 50 channels and all them all to a certain level, such as -8.
Or, is there a way to copy and paste sends to 50 channels at once, without have to copy and drag them one by one? |
Re: Sends question
Then to set the level to be all the same, put all the tracks in a group and make sure send level for that slot is selected as a group setting (by default it isn't part of the global group setting), then just adjust one and all the other will go to the same level in that group. You can delete or make that group inactive after. |
Re: Sends question
Fantastic--thank you so much!
