Avid Pro Audio Community (http://duc.avid.com/index.php)
-   Pro Tools 10 (http://duc.avid.com/forumdisplay.php?f=91)
-   -   Access Violation error on exit (http://duc.avid.com/showthread.php?t=314084)
Legion6789 12-21-2011 05:59 PM
I just upgraded to PT10 from 9 and now I'm getting access violation errors when I try to close pro tools. I end up have to call up the task manager and using "End Process".
Anybody else get this?
TOM@METRO 12-21-2011 06:02 PM
Re: Access Violation error on exit
First, temporarily move all 3rd party Plug-ins to the unused folder. Then trash preferences, and get back to us with the results.
Legion6789 12-22-2011 07:22 AM
When you say unused folder, do you mean a specific folder for unused plugins set up by pro tools, or just move them out of the pro tools plugin folder to a temporary folder so that they aren't loaded on program start?
Also, about trashing preferences, not sure how to do that. I googled around and came across a tech support utility on the Avid website, but it was for Pro Tools 8, not sure if I should try using it with Pro Tools 10. Is there a different tool for 10, or is this a manual process?
filosofem 12-22-2011 11:21 AM
Operating System? Come on, this is fundamental information required for users to help you.
Legion6789 12-22-2011 01:31 PM
Sorry, my bad.
Win 7 x64.
Core i7 920
24GB RAM
PT10 installed to system drive. Separate drive used for recording, WD Caviar Black 2TB.
filosofem 12-22-2011 03:38 PM
Hmmm... listed below is the trashing Prefs information you need, for now.
C:\Program Files (x86)\Avid\Pro Tools\Databases\Unicode delete Volumes folder
C:\Program Files (x86)\Avid\Pro Tools\DAE delete DAE Prefs folder
C:\Program Files (x86)\Common Files\Digidesign\DAE delete DAE Prefs folder
C:\Users\Users Name\AppData\Roaming\Avid delete Pro Tools folder
Empty the Trash Bin and restart computer.
TOM@METRO 12-22-2011 04:16 PM
Thanks for jumping in Aaron.
Legion,
The idea here is to get any possible troublesome or outdated plug-ins out of the mix before moving on. Any way you are comfortable in doing that is fine.
Legion6789 12-22-2011 08:07 PM
I'm going to say tentatively, that it's fixed. At least it hasn't done it since this morning. I have an 11R with the expansion. I noticed that some of the presets would have a weird looking place holder in the signal chain. I didn't realize that I needed to run the expansion pack installer again after I installed PT10 (I didn't uninstall the 11R software). Anyway, seems stable for now. If that changes I'll go ahead and trash prefs and start removing plugins.
Thanks Aaron, Tom!
