Cores and cpu load
after a bit of trial and error, ive noticed that choosing 4 cores in pt instead of 16 cores (in the playback engine pref) i get a lower cpu load % on the system window.
Q: how many cores should be selected on a mac quad to get the best outcome? (lowest cpu load) also, Q: at what % of cpu native load would one expect a system to grind to a halt? ill be doing some more testing to find "that perfect setting" ;-) |
Re: Cores and cpu load
Usual wisdom is to use one less core than what you have so for a dual quad core with hyperthreading turned on that would be 15 as a max.
hey music,
i noticed that when i use most of the cores, the % of cpu load goes up... i would think the % would go down ... any comments on max % cpu load before playback/record stopage? thanks! |
