Avid Pro Audio Community (http://duc.avid.com/index.php)
-   Tips & Tricks (http://duc.avid.com/forumdisplay.php?f=4)
-   -   Quick click setting question... (http://duc.avid.com/showthread.php?t=9676)
emilano 02-23-2003 11:54 PM
Hey there. I'd like to set my PT click to have a jazz or swing feel. Not being too educated in the rhythmic theory area, I have no idea how to do this (in the Tempo/Meter Change dialog window in 5.1.1). Could anyone respond with a quick tip? Just the basic, tizz tip tedizz, tip tedizz, tip tedizz, tip tedizz that would be played on the hi-hat or ride cymbal.
Thanks!!!
AE 02-24-2003 06:28 AM
Re: Quick click setting question...
I don't think you should try this.
A click track with a swing feel would generally be an eighth-note click. Why would that be helpful? A quarter-note click is almost certainly easier to play with.
If you do a quarter-note click, it will have a straight feel so you don't need to do anything special on your end. And this is totally fine; it's the interaction between a straight pulse and swing eighths that creates the rhythmic push and pull of jazz.
Stick with quarter-note clicks, and your jazz artists will be just fine. That is, if they don't mind playing with a click in general...
davip 02-24-2003 11:47 AM
I pretty much agree with the above, but I can imagine situations where you might want the click to imply the swing feel. The best way might be to have a quarter note click with an underlying triplet pulse. Take a look at the Metro click plugin from http://www.tllabs.com.
You could also record a MIDI sequence using hi-hat samples and quantize it to any swing percentage you like if true triplets aren't swingy enough.
leebeefunny2 02-24-2003 11:12 PM
yo
if you had an audio click track instead of midi, then you can use beat detective to manually add a user defined amount of swing. do it to one bar of click...then repeat it. good-luck.
