lounge lizard plug in prob
I just got the Appplied Acoustics Lounge Lizard EP3 electric piano software. It works fine as a stand-alone (using the digi soundcard), but I can't get it to show up in my list of plug-ins when I am recording. I've never had this happen before. It does not come up anywhere in the list. Can anyone help? Thanks
PT 6.4 Digi 001 |
Re: lounge lizard plug in prob
On the MAC compatibility info for LL3, it states that RTAS compatibility is PT7 only. Are you sure that isn't also the case for the PC side? (if it is, it's a mistake on their part; nothing about it on the website)
thanks. i checked the site too--nothing about windows. Hope i didn't waste $230!
Unfortunately I think you have
wait, no, c'mon...really? Is there any software that does the same thing that will work in 6.4 ???
I would have thought that if the Mac needs PTLE7 or higher, then the PC would too. Strange though the website says nothing.
Check in C:\Program Files\Common Files\Digidesign\DAE\Plugins and see if there's a Lounge Lizard file in there. If not, reinstall and make sure you use the above path when it asks where to install the RTAS files. If it IS in there already, then I'm guessing it just doesn't work with PTLE6.4 |
Brandy |
Thanks everyone. I'm getting closer.
I can now load the lounge lizard while in Pro Tools, but it makes a horrible high-pitched feedback noise when I open it. Any suggestions? |
Have you tried a $5 in the brandy snifter sitting on the piano? |
LOL, If you don't know what Lounge Lizard is I can see the humor
Robotboy, have you contacted AAS tech support? |
