Artist Mix Encoder Sensitivity
Does anyone know of a way to adjust the sensitivity on the Artist Mix encoders? I find that I'm often wanting to adjust aux send levels, and volume at the same time on particular FX tracks. The sensitivity of the knobs feel a little sluggish. It's rare that I can raise the level to the desired volume at a steady rate. Since stopping and turning it again sounds bumpy, I end up having to do two passes instead (using flip mode to control the send volume). If there is no way to adjust the sensitivity, any workaround ideas would be appreciated.
Re: Artist Mix Encoder Sensitivity
Sorry there isn't. The current ballistics were thought to be a good balance and liked by most. It was faster in 3.4.1 but nobody liked that.
Having said that, the current setup is pretty good. |
I wonder if it's a problem with my board. It's hard for me to believe that the majority of users would find what I'm experiencing to be okay. The sensitivity for panning is great, and also for plug in parameters. I really only have problems when I'm using the encoders for send levels.
Sent from my iPhone using Tapatalk |
