Color Palette Window- Great Shortcut
Not sure how late to the party I am but i've just discovered a great shortcut for bringing up the Color Palette window in ProTools which I can't believe i've missed:
Double click on the very top of the channel in the arrange window or the very left of the channel in the mix window. Amazing! Hope this helps anyone else who this missed this trick. :o |
Re: Color Palette Window- Great Shortcut
Nice one! Thanks!
Or you just add a key command with the System preferences (on Mac) or with Quickeys (mac or pc) :)
I heavily use the color palette and I couldn't work without a shortcut to open the palette. Cheers Davide |
I use window config for this. ", 1 *" brings up the color palette. |
Thanks, tg |
Keyboard shortcut tab App Shortcuts (on Mavericks, other version may have this menu somewhere else) Add the Application with the Plus button, then write exactly the name of the menu (for the color palette, write Color Palette), and assign a key command (I use control+c) You can add key commands to any function that has a menu name this way. Hope it helps Cheers |
